0 Members and 1 Guest are viewing this topic. Read 13111 times.
192khz, is the maximum ? Or is hd audio possible ?
What do you consider "HD Audio"? Steve
1 the DAC in the MD 801 is a 16 bit DAC , if you want 24/192 you need to get a MD 806 with the special DAC that we use in the MD 807 and MD 809 2 not sure what spotify is 3 the tuner section is at the same level as the MD 1004 the remote is standard , if you want a remote with a touch screen ( available in two months ) it will be optional5 DAB is standard as is DAB +6 Silver is available now
Magnum Dynalab MD-801 Internet Media Tuner. I ordered this unit without DAC and Audio Stage, I'm using the built-in DAC and tube audio stage on MD 109.For cables, I'm using Coincident Extreme power cord and Extreme Shotgun digital coaxial cable, connecting MD 801 to input of MD 109.At 128kbits/sec, it's very good and enjoyable....at 256kbits/sec, it's almost indistinguishable to Analogue...so close, yet Analogue FM is still the best, in audiophile terms, more harmonically complete and most natural. If you have a higher quality DAC like Esoteric D05, you might achieve a better sound, and possibly eliminating the Analogue FM tube audio stage? This simply and completely smokes the SqueezeBox touch! Magnum Dynalab has poured in their best into their new line of internet media tuners, it took 2 years from planning to production. If you're frustrated like me, with the limited good sounding FM stations and looking for alternatives to traditional FM tuners yet not ready to sacrifice the analogue FM music that glues you to the chair...this internet media tuner might be your answer. It is not just an internet radio, it also includes features like DAB, FM antenna input, E-thernet/Wireless network input, and USB input for your playing back of computer FLAC files from your hard drive if you so desired. It's become an iPhone of the audiophile...versatile yet serious enough for demanding audiophiles. I'm a fan of classical and Jazz, in the internet radio world, it has almost limitless stations for you to indulge, and keeping you busy scrutinizing and browsing so many stations...wondering if it's possible to exhaust listening to all the stations in our life time! I think i'll shelve my next upgrade for a while....let's enjoy the music first!
1. the DAC in the MD 801 is a 16 bit DAC , if you want 24/192 you need to get a MD 806 with the special DAC that we use in the MD 807 and MD 809
I am surprised to find out that it only has a 16-bit DAC. I wrongly assumed any 2011 component that could stream locally stored files and cost more than $300 would have a 24/96 DAC as a minimum. Steve
The dac is optional, you can use you're own dac... What i prefere...I hope it is a good dac the use at MD... It will still be better then a bad 24/96. I think.
