0 Members and 1 Guest are viewing this topic. Read 10988 times.
Sounds pretty neat. To bad we don't have Costco here.
Be wary, lest ye become Chuck Josephson!
It has small openings in its structure so a single layer does not block or absorb "all" sound. This gives those who wish a gradient control of reflection to slightly control ...
John,> It is a multipurpose material and is very sound absorbant <Not to burst any bubbles, but that stuff isn't useful as acoustic treatment. You'll get similar results with egg crates, which is to say not very good.--Ethan
I have a large sliding glass door at my first reflection point. I wonder if it would be useful to line the inside of my drapes with it. Do you think it would help?
Mounting it directly on a hard reflective surface will offer less "contol" than allowing it to be 1/2 - 2 inches off the surface. And of course, more layers and larger sizes will allow the adjustement of additional control.
Lots of materials absorb enough at high frequencies to make an audible difference in a room. The problem with most such home-made treatments is they affect only the highest frequencies. So when you use them they give a very lopsided reverb time - too short at the top of the spectrum and with no control at all below 1 or 2 KHz. Sure, you clap your hands and it sounds deader, but when you play real music it's still boomy and indistinct in the midrange.
Shalom! Bringing the thread to life, I hope..John, I have a question, please.What way would you suggest allowing the Easy Liner to "float" 2 Inchs from the wall? ThanksAdam
