AT440MLa for $129.99 on Amazon
0 Members and 1 Guest are viewing this topic. Read 2597 times.
TomS
« on: 15 Dec 2011, 03:36 pm »
Looks like prices have come down a bit from the $159 I had been seeing. Amazon/J&R has the AT440MLa for $129.99 plus $2.99 shipping right now.
http://www.amazon.com/Technica-AT440MLA-Dual-Moving-Magnet-Cartridge/dp/B00009MK3A/ref=sr_1_1?ie=UTF8&qid=1323962927&sr=8-1
Wayner
Re: AT440MLa for $129.99 on Amazon
« Reply #1 on: 15 Dec 2011, 04:27 pm »
Great heads up! Great cartridge!
Wayner
roscoeiii
« Reply #2 on: 15 Dec 2011, 06:29 pm »
For those of you familiar with these, how would you describe the sound? Worth adding to a stable of MMs already including a Shure M91ED with Jico SAS, a Soundsmith SMMC-4 and a Pickering XSV-3000? Or pretty similar in sound to one of these I've already got kicking around?
Gopher
« Reply #3 on: 15 Dec 2011, 06:41 pm »
Its a pretty darn nice cartridge and it surprised me on my former Well Tempered Reference, but if I were you, Roseco, I'd check out the SAE 1000LT.  I have own it and an E, though I haven't personally heard the LT yet.  But at $200 its tough to beat if its a match for your arm (WTA?)
Mitsuman
  • Diamond Tone Junkie
« Reply #4 on: 15 Dec 2011, 06:43 pm »
What type of arm do you have? I would describe it as a bit bright right out of the box. It took about 100 hrs. for mine to tame down a bit. Very translucent highs, a tad hot in the midrange, capable of nice tight and believable bass. My is on a vintage Mitsu DP-EC2 deck, which has a medium-mass S-arm and it does quite well. I had it on a mid-fi Pioneer with ultra low mass arm and it didn't seem as good of a match to me. Hope this helps a bit.
roscoeiii
« Reply #5 on: 15 Dec 2011, 06:49 pm »
I have a Well Tempered Amadeus, which has a pretty light arm on it.
Yeah Fred, I have been thinking hard about that SAE cart...
Mitsuman
« Reply #6 on: 15 Dec 2011, 07:04 pm »
I would think a higher compliance cartridge might be a better match than the 440mla. Sometimes the rules of thumb don't apply, however. I know my low-mass Pioneer likes a Grado vs. the 440mla, but YMMV.  :D
neobop
  • BIRD LIVES
« Reply #7 on: 16 Dec 2011, 03:55 am »
Pretty good deal considering the stylus costs $120.
Many people find the highs a little hot. I used to load it at 32K and very low capacitance. Best if you can keep the total less than 200pF. Compliance is 10cu @100Hz which is around 18cu at standard 10Hz. I seemed to get better performance with low mass arms. Guess it depends on the arm.
