Core Audio Technology Kratos Fully Digital amplifier system
0 Members and 1 Guest are viewing this topic. Read 2314 times.
mintzar
  • I bend digital to my will
    • Core Audio Technology
The Kratos is a two-channel fully digital amplifier design.
The amplifier accepts a digital signal either from USB or SPDIF. This signal is then reclocked, amplified in the digital domain, reclocked again, and then converted to analog at the output of the amplifier.
Core has spent the last two years developing its power supply technologies specifically for digital systems alongside engineers from NASA and Rockwell Automation. There is not a power supply that comes close for digital audio. If you believe that regulators  or filtered batteries are the 'be all' of power supply design for digital you have not even scratched the surface of what a properly designed power supply can do for your audio system. These power supplies are BRAND NEW within the last two months, they are a ground up redesign from our old power supply -- not a single part or circuit remains from the original design.
It is this power supply that removes amplitude distortion entirely from the digital system, allowing the natural harmonic content and beauty to flow unlike any other system on the market.
The digital amplifier allows an individual to remove thousands of items from the signal path including several stages of filters and conversions. It is as close to a perfect signal path as you can get. You remove a separate DAC, Preamp, and amplifier as well as the interconnects connecting them. All one needs is a single digital cable.
This system has a built-in voltage controlled attenuator that resides outside of the signal path for the lowest possible distortion. No passive, active, DSP, or optocoupler preamp is as low distortion. No filters, DSP, or passive components to remove the natural time and tune of the music. The result is an extremely high resolution sound that just sounds like music. If the music is rich and lush then you hear it, if the music is dynamic and forward then you hear it in all its splendor.
20wpc into 8ohms
-152dB S/N ratio
129dB Dynamic Range
Prices:
$1600 for the Kora Kryptos
$2500 for Kalos Kryptos
For more information and expanded pricing options:
http://www.coreaudiotechnology.com/kratosdigital.php
About our Power Supplies:
http://www.coreaudiotechnology.com/kallos.php
All Core products come with 30-day trial period and 90-day full-value upgrade policy.
Coming soon:
Core's all in one server. Music server + digital amp in one box. 7 dedicated power supplies for motherboard, Sound Card, Hard Drives, amplifier input, output, clock circuit, and digital chip. No more cables and a straight i2S signal path with computer-controlled amplification. Simpler, cheaper, and even better sound.
« Last Edit: 14 Dec 2011, 04:37 am by mintzar »
