Audio/Video Gear and Systems
Owner's Circles
Well Tempered Lab
/mp
WTT Ref
WTT Ref
0 Members and 1 Guest are viewing this topic. Read 2245 times.
Neon
WTT Ref
12 Dec 2011, 10:13 pm »
Dear Circle
Anyone know the correct overhang to use for cartridge set up with the WTT Ref Arm ? I understand the arm is rotated to properly set the overhang
Dana Woods
code4246
Re: WTT Ref
13 Dec 2011, 08:47 am »
do you have the factory supplied alignment protractor ?
that has a circle printed on it to which you align the end of the tonearm.
gagamut
ยป
Re: WTT Ref
Reply #2 on:
14 Dec 2011, 12:12 pm »
Hi,i'm a WT reference user before.i just measure the protractor,hope can help anybody.
overhang;1.6cm
inner null point;5.9cm
outer nul point;11.73
last thing;hope i measure is correct
code4246
Re: WTT Ref
Reply #3 on:
15 Dec 2011, 01:31 am »
those numbers seem right,
i just measured the circle on my wt protractor and its approx 33mm in diameter.
Owner's Circles
Well Tempered Lab
/mp
WTT Ref
