I've tested the amp with shorting plugs and it's more or less dead quiet. Shorting plugs on passive preamp, more or less dead quiet. Add phonostage: hum and buzz from hell. I've floated the phonostage and that did nothing. The three other pieces of equipment I have (passive preamp, dvd player and turntable power supply have two pronged plugs), so there's nothing to float there. Plugging into different circuits doesn't help either. And like I mentioned, I bought a Jensen transformer and I was praying it would do the trick but alas no such luck.
I don't own a tv so no issues there. There is an internet cable line hooked up to my dvd player, but during testing I've unplugged it and moved it away--with no effect. To top it off, when my wife turns on the space heater in her office, it emits a buzzing through the speakers that's intolerably loud
I'm going to try breaking the circuit of everything else in my house except the one for the electronics and see if that does anything.
The transformer hum I can live with, especially now that the amp is far away from my seat.
At any rate, back to the question at hand. Sounds like no one has experience trying out different input tubes and that the main consideration is noise. So, one low noise tube 'where it counts' and one standard one. Right?
