Streaming Netflix to NuForce BDP-93 Xtreme Edition?
0 Members and 1 Guest are viewing this topic. Read 2334 times.
jazzcourier
« on: 12 Dec 2011, 06:14 pm »
I currently stream Netflix through my Roku box with good results.Recently purchased the Oppo NFX edition of the 93 and want to stream it through the Blu-Ray player....Dongle in .....source the "home" selection on the remote and i have the Netflix icon....selecting this icon i get "cannot access Netflix account...try later" which i have and have.......... I have done no upgrades to this unit since purchase and i m wondering what i am missing,what do i need to do to complete the process of streaming Netflix to the Oppo? Anyone have any ideas or suggestions and solutions? What am i missing? Did i sleep through this class? I didn't know it was on the test...........
                               Thanks- John
srb
Re: Streaming Netflix to NuForce BDP-93 Xtreme Edition?
« Reply #1 on: 12 Dec 2011, 06:52 pm »
Are you using a wired Ethernet or wireless WiFi network connection?  Have you run the "Connection Test" under Setup Menu > Network Setup?
jazzcourier
« Reply #2 on: 12 Dec 2011, 07:56 pm »
Thanks Steve- We are going wireless, and will TRY the connection test in the setup menu and report back!
srb
« Reply #3 on: 12 Dec 2011, 08:09 pm »
To sucessfully configure a wireless connection, you would either have had to scan for or manually enter your wireless router's SSID, then enter the Security Mode and Security Key/Passphrase or use a WPS PIN number if the router is WPS compatible.
jazzcourier
« Reply #4 on: 12 Dec 2011, 09:18 pm »
Into the setup menu and onward to success!  I was able to download the current firmware upgrades and Netflix is looking and sounding great! On behalf of all the Flintstones ,we thank you!
