The amazing Imaging of the BDP-1
0 Members and 1 Guest are viewing this topic. Read 1963 times.
Robert D
« on: 11 Dec 2011, 04:03 pm »
James, and others as it stands for now my Speaker cable runs are 27 ft long. Each.
I'm running 2 x 4bsst2's vertically bi-Amped .
I looks like I'll be able to go with new cable runs of Max 7ft ...... for each Speaker .
My question is How will the wonder full colors change of the BDP-I
Imaging..soundstage.. Bass
Robert
voobgynmd
Re: The amazing Imaging of the BDP-1
« Reply #1 on: 12 Dec 2011, 06:52 am »
Shorter runs of speaker cable are generally better than longer (>20 ft.) runs as I understand it. System should sound even better I would think with the shorter runs.
SamKVA
« Reply #2 on: 12 Dec 2011, 08:41 pm »
Robert
I always recommend long interconnects and short speaker cables and use mono-blocks with 1 meter speaker cables. You would never know my interconnects are 40 feet long but you won't get away with cheap ones and a fully balanced path and cables are a plus.
Sam
yo2tup
« Reply #3 on: 12 Dec 2011, 11:11 pm »
the sound of the bdp-1 will stay the same, but the sound coming out of the speakers may change from the speaker cable change  :scratch:
