Signal to Computer
0 Members and 1 Guest are viewing this topic. Read 1183 times.
Mikeinsacramento
Signal to Computer
« on: 10 Dec 2011, 02:25 am »
I want to send a signal from a turntable to my Mac Mini 2010.  For the purpose of listening over my computer speakers.  How do I do that?
Wayner
Re: Signal to Computer
« Reply #1 on: 10 Dec 2011, 12:46 pm »
Well, you need a phono preamp (the record needs to be RIAA equalized) and then coverted to either a USB or, if your computer has line inputs on the sound card, then just some interconnects from the preamp to the computer.
If your computer has no line inputs, this will be a problem. There are phono preamps with USB output, but they can be a little spendy.
W
AllynW
« Reply #2 on: 10 Dec 2011, 03:10 pm »
Follow the two product links below and it should get you there. Of course you can get the cabling at Radio Shack and VP130 from ebay or audiogon.
http://store.apple.com/us/product/M9573LL/A
http://www.rolls.com/product.php?pid=VP130
Have fun.
louistoth
« Reply #3 on: 16 Dec 2011, 07:26 am »
I searched the product but this is not available in USA. Can you suggest me another product as smiler to it.
Mikeinsacramento
« Reply #4 on: 25 Dec 2011, 06:21 pm »
OK, I hooked up a little pre-amp.  And the little RCA/3.5 adaptor between the pre and the Mini.
When I go to Sound in User Preferences, my "Line In"  Input is showing a signal from my record.
When I go to Output, where I have no signal, it says "The Selected Device Has No Output Controls".
Any thoughts on what this means and how I overcome it?
