goes black ..... looks like a standby mode.
0 Members and 1 Guest are viewing this topic. Read 1531 times.
Robert D
« on: 9 Dec 2011, 12:05 pm »
Internet Radio :
If the BDP-1 is left on a Radio Station for a short period of time, I have noticed that the front display for the BDP-1
Is the there some button that I can press so the display turns itself back on.
I do not want to have to press the power button because that will turn off the BDP-1.
Thoughts please Robert
  • The Demo is Everything!
    • http://www.bryston.com
Re: goes black ..... looks like a standby mode.
« Reply #1 on: 9 Dec 2011, 12:15 pm »
Internet Radio :
Hi Robert,
Yes just push any input or change the station or song etc to refresh the display  - it is better that the display does not stay on all the time for life expectancy.
james
Robert D
« Reply #2 on: 9 Dec 2011, 10:02 pm »
Hi Robert,
james
Thanks for the Tip   :thumb: :thumb: :thumb:
Works just fine
Thank you James
Robert
Alpha10
« Reply #3 on: 10 Dec 2011, 09:09 am »
Robert, you can change the duration and intensity of the display, if you press, I think it is the left and up buttons a few times quickly. I keep mine on intensity 1 (lowest) and 10 sec timeout.
Cheers
ralph1950
« Reply #4 on: 11 Dec 2011, 03:57 pm »
The SP3 does the same.  With just a nudge of the volume control, it comes back to life.  I like it this way since my components are in full view, in a dark room this is more desireable.
