0 Members and 1 Guest are viewing this topic. Read 9524 times.
Looks great Tom. If you are looking to poke around for vinyl in Chicago this weekend, I'd recommend the following:Jazz Record Mart (downtown; genres: jazz, duh)Reckless Records (3 locations, incl 1 downtown on Madison; genres: rock, alternative, hip-hop, punk, metal)Dusty Groove (a bit removed from downtown, near Wicker Park; genres: soul, R&B, jazz, some hip-hop & rock but not much)Permanent Records (a very indie strore near the restaurant A Tavola I recommended in another thread; genres: pretty indie and experimental, but some classic rock and other vinyl too)Hyde Park Records (Hyde Park, my neighborhood; genres: also strong on soul, jazz and rock. Also a solid classical collection, a ton of $1 bargain bin titles, though they are not organized in any way)MusicDirect (West Loop, an unmarked warehouse so look up the address but they have used vinyl in addition to the tons of new stuff on their website; near the Publican restaurant I'd recommended) Also, IIRC, doug s here is a big Empire fan. Might want to see what tips he has for those tables.
I would reconsider replacing the Empire mat. I have found that the edge suspension of the record is most beneficial in reducing platter noise. This is the same style mat used on my Empire 598 and if you will notice, the very outer edge of the mat is the only surface that comes into contact with the record. There is a higher ridge for the 10" and 7" 45s, too.If you don't want the mat, I'll take it.......Wayner
This is cool!I'm also using the phonoclone preamp and DL103. I power the phonoclone with +/- 18VDC SLA batteries and the DL103 has the Soundsmith ruby cantilever and line stylus. I like how the stock phonoclone circuit values are tuned for the DL103's gain and impedance. This is quite the spine-tingling cart/preamp combo for those of us who don't mind slinging a little solder. Russ
Curious what might be "ground" in relation to your spindle or thrust bearing.Does your bearing have bronze bushes or is it solid cast iron?Is the armature or your motor silver or gold?Congratulations on joining the empire camp. You have a leg up on a lot of people entering the vinyl fray. The table can justify a much nicer arm.Have a good base and mounting location will benefit. Try stp in your spindle.
