FS: Outlaw Audio 7100 - 7 Channel Amplifier
0 Members and 1 Guest are viewing this topic. Read 1573 times.
mojave
« on: 6 Dec 2011, 08:34 pm »
Outlaw Audio 7100 - $550 plus shipping from 68134
Designed and built in the USA
This is one audio product that I already feel like I will regret selling. It has been the centerpiece of my audio system for about 5 years. It is rated at 100 watts per channel, all channels driven, but if it is anything like its successor, the 7125, it measures even better than its specifications.
About 1 1/2 years ago I bought a Digital Amp Company Cherry Jr. amp and have been using it for my mains. The 7100 was still used for the surround channels when watching movies. This year I added some more Cherry amps and am now at the point where I don't need the Outlaw amp anymore.
This is a great amp for anyone wanting to move to separates for their home theater. The amp was purchased as B Stock when Outlaw was transitioning to the 7125 amp. The amp is in excellent shape and looks almost new.
As you can tell from the specs, this amp has an incredibly low noise floor. It also only needs 1.00 volt for full rated power so it will even work well with most HTPC soundcards. I always drove the amp directly from my HTPC.
Specs:
- Power Output (FTC): 7 x 100 watts @ 8 ohms, 20 -
    20kHz, 0.05% THD, All Channels Driven;
    7 x 165 watts @ 4 ohms, 20 - 20kHz, 0.05% THD,
    All Channels Driven
- Signal to Noise: 119dB "A" weighted
- MFR: 20Hz. -20kHz. +/- 0.1 dB at rated output
- THD: < 0.05% at rated output, all frequencies,
    <0.01% at 1 kHz.
- IMD: < 0.05% at rated output.
- Power Bandwidth: 5Hz - >100 kHz +0/-3 dB
- Damping Factor: > 400 from 10 Hz to 400 Hz
- Crosstalk: > -90 dB from 20 Hz to 20Khz
- Gain: Voltage gain of 28.
- Slew Rate: 50v/Microsecond
- Input Impedance: Nominal 50 kOhms
- Input Sensitivity: 1.00 volts for Full Rated Power
- Size: (HxWxD): 5" with feet x 17.2" x 16.2"
- Weight: 51 Pounds
Review in Secrets of Home Theater and High Fidelity
Review at Enjoy The Music
jackman
Re: FS: Outlaw Audio 7100 - 7 Channel Amplifier
« Reply #1 on: 8 Dec 2011, 11:44 pm »
I had one of these a few yEars ago and it was a solid, very good sounding amp.  Very well built and compact.
