0 Members and 1 Guest are viewing this topic. Read 16897 times.
From what I've seen, that is a very capable lens - right from f1.4 on up.Plenty of samples scattered throughout this thread... http://www.pentaxforums.com/forums/pentax-slr-lens-discussion/149865-sigma-30mm-f-1-4-thoughts-examples.html
If I didn't already own Canon 35mm f1.4L, I would definitely try the Rokinon 35mm f1.4, which is Rokinon/Samyang's best lens to date with excellent resolution. It's manual, but it shouldn't be too much of an issue at short focal length like 35mm, and at around $500, certainly a bargain.http://www.photozone.de/nikon_ff/658-samyang3514fx
Well...this is timely. Don't know if this helps, but...I'm in Maui this week and this morning climbed up (actually...drove up) to the top of Haleakala with my D7000. In the 45 minutes or so BEFORE sunrise I pulled out my 50mm f/1.4 prime since my 28-300mm was having trouble. I was astonished by the light it picked up...and how well it auto-focused handheld. Other Nikon & Canon people were getting basically nothing at the time I got this shot this morning, including all the tri-podders. Some of them wanted to borrow the lens...yeah, right. Reduced to 1/2 size, a 95% JPEG. Sure, it's 6400 ISO and a wee bit fuzzy but for the amount of light available it did a pretty nice job.(f/1.4 at 1/500 sec)Hope this helps.
Just opened up the box like 30 minutes ago. First impression, very easy to use. Makes me happy when I hold it in my hands. It's slightly smaller and lighter than the Nikon FE. Design wise, it's sweet. I am pretty happy with low light pics up to 2500 iso at F2.Tried to manual focus, but, when using the focus ring, nothing happens at first. Switched on the EVF, then you can see the manual focusing working. Forgot it's not a SLR, so you have to use EVF when manual focusing. Also, manual focusing is a pain on the X100. You turn and turn the dial, and the focus field changes either very slowly or very abruptly. The focusing is not mechanical like on a SLR lens. I wouldn't even use the manual focus unless I have to.Shutter speed is on a dial and is self pretty explanatory. I think my Nikon D90 has more speeds though. Aperture dial is on the lens. It's easy to turn as long as you are using the knurled protruding portion. ISO is pre-programmed on the function button. Just press the function button and use the arrow button to go up or down on the menu screen or in the EVF. One dislike is the positioning of the battery and SD card door. It's right next to the hole where you screw in the tripod head release plate. So, each time I need to access that door, I need to remove the release plate. Another dislike is I tried to plug in a mini USB to try to access the card without accessing the battery door. I couldn't plug the minu USB cord in. The input connection is slightly smaller. Stupid USB port is proprietary. Maybe there is an ultra mini USB connection standard that I don't know about?I have the Fuji MX700. It's an ancient model from like 1996 if I remember correctly. I haven't used it in quite awhile, but I remember the menu and general GUI to be very similar to the Fuji X100.
