Shure SRH-840's
0 Members and 1 Guest are viewing this topic. Read 7655 times.
saisunil
Re: Shure SRH-840's
« Reply #20 on: 10 Jan 2012, 11:25 pm »
That's right ... It is a grey / black fabric between your ears and headphone ...
bprice2
Re: Shure SRH-840's
« Reply #21 on: 10 Jan 2012, 11:56 pm »
Thats what I thought you meant when I first read your suggestion.  When I gave it a try a few nights ago I got very different results, and not for the better.  Bass became non-existent, treble became harsh and the overall presentation became flat.  I put the other set of pads on and all was well again.
I think that maybe removing the covering material lessens the ability of the pad to provide seperation between my ear and the driver (just a theory), which is causing the ill effects.  So, I'm going to try adding some extra foam under the pad to see if that helps, assuming there's enough room.
I do want to thank you for bringing this idea up.  It seems to make sense that removing obstacles between the drivers and the ears is a good thing.  It just didn't work for me.
saisunil
Re: Shure SRH-840's
« Reply #22 on: 13 Jan 2012, 04:11 am »
There we go ... trust your ears :)
bprice2
Re: Shure SRH-840's
« Reply #23 on: 13 Jan 2012, 07:33 pm »
Good advice, but in this case you probably deserve more credit for your mod.  While i still don't think i like the open pad as well as the closed, it turns out (I think) that my HP amp was low on juice when I first checked out your mod.  Whatever it was, it sounded better upon a second listen.
