OK, overall sound is good, very good. I'm not use to high end hifi stuff but I've to say that those speakers sound better than anything that I've ever heard.
Only small complain is that one of the woofers did a small "rattling" that went away after a period of break in.
If you are planning to do those speakers to hear low quality records, think again, the 1801 have the ability to do the good recors to sound better but the bad recors will sound horrible. They will reinforce what good or bad is in the record.
And, one last word ... think abt this ...
If you plan to do the 1801, enjoy your time and learn new things during the process you are on the rigth track, but if you are only going to do them just to save some $$$ don't do it, you better buy something in a shop. If you are a little bit perfectionist (as I am) this proyect will take 3 or 4 times more time and effort that you thougth on the first place.
Salva
