trouble with pointing alias to NAS trick
ratso
« on: 2 Dec 2011, 03:01 pm »
i posted this in the apple forum, but they get so many posts that if you don't get an answer immediately, you are usually pushed down to page 37 in a hour or so. and god knows why, years later, apple still hasn't fixed this (not like anyone is using external storage these days) :roll:. this trick is used to prevent itunes from resetting your library back to the default spot if you start itunes and forget to turn on your NAS first (instead of, umm... just giving us a warning?). the idea is to have an alias of your itunes folder in the default spot that points to your real itunes folder on your NAS. so that's what i have: i have an alias itunes folder (titled itunes) in the default location of users/music on my 2011 mac mini running latest itunes/lion. it points to my real itunes folder kept on my nas. itunes itself is pointed to the default location of users/music/itunes/media (i am recalling all this off the top of my head, so forgive me if i have a folder name wrong here, the point is everything is in/pointing to it's default locations. when my mac starts, i get the "can't find - please select" library warning. 2 strange things - if i select library and click on the same alias itunes folder that itunes is already pointing to, it works fine. after going through this and everything is working fine if i quit itunes and restart it, it still works fine. but when i completely shut down the mini, it goes through an itunes "saving library" thing and then when i restart it, the same problem happens? anyone know? thanx in advance.
ratso
Re: trouble with pointing alias to NAS trick
« Reply #1 on: 2 Dec 2011, 04:16 pm »
BTW if any enterprising computer guy wants to write a simple program that would do this (prevent itunes from starting if your nas isn't on) that would not suck. i know that there are apple scripts that can do this, but every time i look at them i get confused and my head starts to hurt.
Crimson
« Reply #2 on: 2 Dec 2011, 07:37 pm »
You may want to add your mounted nas volume to your login items (Preferences >> System >> Users >> Login Items).
ratso
« Reply #3 on: 3 Dec 2011, 02:22 am »
what happens if it's part of the login items but it's not turned on? i don't want to run my NAS 24/7 as i am only home and using it a few hours a day.
lcrim
« Reply #4 on: 3 Dec 2011, 02:33 am »
I have seen this justification rather often and always wonder just how much you saved by shutting down the NAS.  I could be seen as picking an argument but frankly if you did some investigation you'd find that the savings in electrical costs (a few dollars a month even in Manhatten) would not be worth the PITA this causes.
Larry
Crimson
« Reply #5 on: 3 Dec 2011, 03:59 am »
You'll get an error message indicating it failed to connect. But I agree with lcrim. If you're going to treat your NAS like a TV, that kind of defeats the purpose. You'll get much better throughput and zero headaches if you simply use decent externals, either FireWire or USB. I have quite a bit of NAS at home, but my music library is strictly external on a dedicated machine. With iTunes' home sharing (and the recently introduced iTunes Match), library access from a networked machine is simply a click away. Without NAS.
ratso
« Reply #6 on: 3 Dec 2011, 06:12 am »
thanx to you both. actually, more than energy savings is the fact that my nas isn't exactly whisper quiet when it's running. it's in my upstairs bedroom well away from my sound system so it doesn't bother me when music is on. but it's a little annoying when i'm upstairs. also i wonder about what it does to the life span of the nas/drives to leave it on all the time. i also need my nas huge storage (up to 12 gb) because i plan on storing blu-rays on it as well as music.
