0 Members and 1 Guest are viewing this topic. Read 11414 times.
I read somewhere online that the Audax woofer has a free air resonance of 35Hz; therefore, the modifications have lowered the lower end of the speaker response from 55Hz to between 40Hz and 35Hz.
Loudspeaker Enclosure Modification – Part 6: Listening ImpressionsMy Tangent RS2 speakers now sound much more realistic to me. The bass extends lower, and the midrange has increased clarity. Since the tweeter is sealed, the modifications don’t affect its performance, however, the balance between the treble frequencies and the mid/bass frequencies sounds better matched to me. Using the Odyssey test tracks played on a Redbook CD, a 40Hz tone track played was previously inaudible prior to the modification, and is now clearly audible following the modifications. I read somewhere online that the Audax woofer has a free air resonance of 35Hz; therefore, the modifications have lowered the lower end of the speaker response from 55Hz to between 40Hz and 35Hz.
I kind of doubt your modifications gave you deeper bass. More than likely you damped some of the midrange making it seem like you have more bass. To really get any more bass, you would have had to increase the enclosure volume considerably.You can easily verify system resonance by running a before and after impedance curve. An impedance curve will show you where the system resonance is.
My understanding of the attenuation provided by the felt is due to conversion of sound pressure vibrations to heat by friction of the fibers in the felt rubbing together. Yes there is also less surface area directly exposed to the interior sound waves, but there are also plenty of gaps of varying sizes between the felt pads,
The energy feed to the cabinet thru the airspace is easily shown to be less than a third of the energy that gets to the cabinet walls. In practise it is less than this.dave
