Bridged 4B ST Question
0 Members and 1 Guest are viewing this topic. Read 1958 times.
clayeton
« on: 1 Dec 2011, 09:23 pm »
I currently have a 4B ST and have been looking at either getting a pair of 7B ST's or a 14B SST.  If I was to bridge my 4B ST and add a second 4B ST - would it come close to the sound improvement I could expect from a pair of 7B ST's?
Thanks for the help,
Clayeton
SoundGame
Re: Bridged 4B ST Question
« Reply #1 on: 1 Dec 2011, 10:22 pm »
Nope.  Bridging Bryston amps is not something you do for increased performance - it raises the distortion levels.  if you don't absolutely need the extra power, you are probably better off going to a 4B-SST amp for enhanced performance.
srb
« Reply #2 on: 2 Dec 2011, 12:19 am »
It's also not something you would normally do if your speakers are 4 ohm or below.  The bridged amplifier sees half the impedance, and a lot of amplifiers don't like to spend a lot of their time at 2 ohms or below.
JfTM
« Reply #3 on: 2 Dec 2011, 12:46 am »
Isn't a 7B bridged?  The two modes are based on how it is bridged?
larevoj
« Reply #4 on: 2 Dec 2011, 03:29 am »
You are better off with 7BSST2.
alexone
« Reply #5 on: 2 Dec 2011, 03:59 am »
...correct me if i'm wrong but bridging an amp (here the 4B) might give more power BUT it reduces the damping factor (up to 50%?!?) which is important for bass control.
al.
