0 Members and 1 Guest are viewing this topic. Read 18791 times.
For your info, I just got in a nice older 550 hybrid amp (black faceplate, captive power cord). I am planning to upgrade it to a 600R and sell with a full new AVA three year parts and labor warranty and our standard 30 day satisfaction guarantee.Asking price $2595. Might be within your budget,Frank Van Alstine
I used to power my 2ces with a pair of ARC classic 120's...
When I was considering a pair of Quattros, my dealer setup a Cary SLI80 integrated (which I have been using at home for the last 9 years) and this little integrated worked beautifully. The SLI80 is 40 watts/channel in triode and 80 in utralinear. It drove the Quattros with no problem at all.
Was this a custom SLI-80? The Quatros require first-order crossovers before the amplification stage, and there is not a pre-amp out / amp in option on the SLI-80. Some integrated manufacturers will drop in some caps in the signal path to facilitate the use of Quatros (for example, Ayre will do this in their AX-7e), but it's custom config that commits you to the Quatros (or at least the Vandersteen line).Back to the OP's concern...The DNA-125 is a fine amp, and of all your other equipment, it's probably the last piece I'd dump (particularly mated with the 2ce Sig II's). With only considering the equipment / factors listed, I'd also point toward the "pre-amp".
Cary will make the adjustment for a nominal fee (about$170).
It puts out about 200wpc and seems to have enough current.
One last thing..has anyone tried bi amping with a 5 channel amp?
