Other Stuff
Archived Manufacturer Circles
Hagerman Technology
hagtech
Piccolo fixed gain
Piccolo fixed gain
0 Members and 1 Guest are viewing this topic. Read 1784 times.
Lengy
Piccolo fixed gain
29 Nov 2011, 04:32 pm »
I have a Piccolo and want to fix the gain at 20db, which resistors do I use to set this, or which terminals do I link between on the switch position (a diagram would really help me)?
John
poty
Re: Piccolo fixed gain
2 Dec 2011, 07:34 am »
If you don't solder the S2 switch:
White arrows - to allow power to the Piccolo.
Red arrows
- 0 dB
Green arrows
- 12 dB
Blue arrows
- 20 dB
Cyan arrows
- 26 dB
P.S. Forgot to mention - If you use only one gain position you can use only a pair of the R2 resistors (not solder all others at all) correspondent to the gain.
Lengy
Reply #2 on:
3 Dec 2011, 09:48 am »
Perfect, Thank you.
Other Stuff
Hagerman Technology
hagtech
Piccolo fixed gain
