0 Members and 1 Guest are viewing this topic. Read 14006 times.
I store my music on externals (firewire and hot swappable). That gives more flexibility and allows you to keep multiple backups. (Almost forgot to mention that I use 1 TB, 5400 rpm drives. These are plenty fast for music and quieter. There are also some restore issues with larger drives.)You could use your mini as a dedicated server, which is how I have mine set up (with a 60 GB SSD and 8 GB of ram). It makes for a very nice unit, especially with Pure Music as the player.
I store my music on externals (firewire and hot swappable). That gives more flexibility and allows you to keep multiple backups.You could use your mini as a dedicated server, which is how I have mine set up (with a 60 GB SSD and 8 GB of ram). It makes for a very nice unit, especially with Pure Music as the player.
...........and the Apple Store salesman referred me to this forum.
I have the mac mini server that I dead head and mainly use it as a iTunes server. It's the central point for music, videos and ebooks for all other computers (windows, mac) and devices like the Apple TV and Bryston's BDP. It's also the house file-server, time-machine server (and client) and online backups are enabled. I've selected to not have any computers close to my stereo for various reasons: ugly, prefer to avoid wall warts, ugly, HDD noise, ugly, and there is no need to have a mac mini or any computer since I have the BDP. Did i mention it's ugly? I do have everything in a cabinet, but it would still be ugly... Obviously there are a thousand ways to do this, this is my preference. I normally will just stream the video or music to the other computers and all ATVs point to that iTunes server using the home networking feature. It's configured to also start iTunes in the case of power-outage, or a reboot. I also use it to automatically rip CDs with little interaction from me, and I will always review the album art, song titles after each rip. It's set up to easily update the Bryston BDP after I've uploaded/ripped more music. Since the mac mini is configured to be a file server, it's easy to download songs to it (hdtracks, etc) and again sync that to the BDP and even convert the FLAC to AIFF for the iTunes Server. I do use screen share to tweak the text after a rip, do the flac to aiff conversion, and force iTunes to save the album art to the actual file.With iOS5 out it's now become the iPhone/iPad wireless backup location as well. It seems with each passing year, this eco-system just gets easier, and eager to see if some of the backup duties can also migrate to the cloud.
Hi!Seems you got it the way I want it. Glad to hear it's working fine. Please could you clarify a bit further:You rip on the Mini, as in you have an extra cd-drive, or as in the former Mini? (I need to order one, so would need an extra drive, or rip on my Macbook and wire it to the server)Do I need the server edition for this all to be possible, or would the standard edition suffice. (never touched Max OsX server edition)Since you use it as a file server too I assume you have some extra HDD attached? the 750gb is hardly sufficient for Music-storage.What exactly do you mean when you write "It's set up to easily update the Bryston BDP after I've uploaded/ripped more music" How have you done this?Thanks! you're helping a lot.Marius
I have the external USB DVD drive to rip, same one that is sold for the Macbook Air. You do not need the server edition anymore. I only picked up the server edition because I wanted to run the Time Machine Server, now that you can purchase it cheaply from the App Store, any Mac can become a server. One could easily use an AirPort Extreme or various NAS boxes to act as a TimeMachine server. I configured the mac mini server with 2 500 GB drives skipping SSDs since there's no real advantage for my needs, I've have the following drives: 500GB (2nd internal): used as a common file share2TB (FW): used as a media drive for the iTunes server3TB (FW): used as a the local time-machine drive and the time-machine server drive. 4TB (USB): It's a first gen drobo drive that rarely is turned on, mostly manually archives original files, but it's too loud to keep on all the time.: Early next year, i will need to increase the storage for both FW drivesOnly backup only snags the data and media drives. Once iCloud becomes more mature, I will restrict to just backing up the data and music.As for interfacing with the BDP-1, I use a script to copy the files over. There's an app in the app store that does this in a GUI fashion that I've pointed out in another thread. http://www.audiocircle.com/index.php?topic=99776.msg1016882#msg1016882
Hi Skunark,Dropsync caused me some trouble, but those might be related to the power-issues I had with the hdd's. It skipped files intermittedly, so I had to check manually and redo it several times. Deleted it again but since you're very positive about it I'll try it again. In the meantime I had been downloading Synkron http://synkron.sourceforge.net/ which is also a Gui around rsync as I understand it, and free to top that. You have any experience with this? Seems rather nice, and does it's work automatically so it seems.So you rip/download on your Mac Mini and then copy to the BDP, with is then backed up by Dropsync. Or do you set Dropsync to sync your rip/downloadfolder to the BDP. I like to keep my Mac (book for now, mini for later) as free as possible and after ripping/downloading music files I edit tags/albumart, copy to BDP and backup drive. Then delete from the Mac. Which would be the easiest to automate you think? I saw that Synkron can sync multiple drives, that might be the solution?Marius
Synkron might be the better approach since it's free! I will try it out tonight.I just use a script that uses RSYNC to copy the iTunes and HiRez directory from the mac mini to the BDP. I also use that script to do non-BDP related activities, it was simple to add the BDP to it. The script is nothing more than a "rsync -avz /path/to/source /path/to/destination", but it's tweaked to focus on AIFF and FLAC files. My view is that if you want to use a script, you need to know how to write the script, and all the area's around using a shell, etc. Which is why I've recommending folks use the Gui, it does the same thing and it's a difference of check-boxes vs command line switches. DropSync and various other products will use a RSYNC under the hood, if there's a failure, it should be as simple as re-running the script, as it should be generate a checksum on each file to make sure it copies over the new changes and also to confirm that it was properly copied. It can also be configured to do more or less checks as you see fit, checksum only, timestamp only, delete at destination, etc, which i'm sure varies by each application. If the BDP drive is formatted as FAT32, you might see if there is an option related to that. You normally have to enable a "fuzzy" option to deal with the file name restrictions and time stamp issues with FAT32 file-systems.
Ok great. please report back, looking forward to that your mini to bdp procedure is clear. do you back it up automatically too? and your files stay on the mini? I would have thought that won't last for long, especially with the hires files coming in lately....Marius
I have 5 machines backblazed. Like you said, insurance. (They do offer the option, as you're probably aware, of hard drive restore discs shipped to your door in case of catastrophic failure).
Synkron did the trick, it has a weird app behavior while running but seems to have all the key features one would want if using a script. I can select just the iTunes folder, blacklist the ALAC, MP3s, DRM files, Video files and just sync the music. Using a multi-sync feature I can also select the HiRez folder to snag that as well in a single step.
