Optimum Partition Size for BDP1?
0 Members and 1 Guest are viewing this topic. Read 1607 times.
Marius
« on: 29 Nov 2011, 01:46 pm »
Hi,
Since I am on the verge of buying a 2 or 3 tb My Book Studio, (with USB 2 to play to BDP1 and 800 Firewire to load from the MAC), I would like to ask you whether there would be an optimum partition-size for the BDP1. fat32 can have max partitions of 8 tb I believe?
Would this be very convenient for the BDP1 or would it be better to have the My Book partitioned in smaller virtual drives. And would it recognize those?
Marius
  • The Demo is Everything!
    • http://www.bryston.com
Re: Optimum Partition Size for BDP1?
« Reply #1 on: 29 Nov 2011, 04:51 pm »
Hi,
Marius
Marius,
Chris says - are you thinking of using both interfaces at once or loading just using Firewire? Chris feels multi-partition drives seems to slow things down on mount side.
james
Marius
« Reply #2 on: 29 Nov 2011, 04:59 pm »
I was thinking of just loading using firewire. But not sure, as there seems to be some debate about the speed-advantages.
The multi partition question: if you can confirm that 3tb can be read by the BDP without problem, and is fine in terms of speed, I have no need for that. Had heard that fat32 posed some size limitations, that's why I wanted to be positive in that respect.
HDD's are getting more and more difficult to order as we speak....But just now I stumbled on this one: http://www.bhphotovideo.com/bnh/controller/home?O=&A=ShowProduct&Q=&sku=830635&is=REG
 2TB bus powered!
Amazing really.
Marius
Marius,
james
Marius
« Reply #3 on: 29 Nov 2011, 05:29 pm »
sorry for that, a misplaced ]
edited.
There is a bunch of message text included in your link making it non-working.
