TacT M2150XDM Integrated Amplifier (with full ABERDEEN MODS)
0 Members and 1 Guest are viewing this topic. Read 1534 times.
HerculePirate
True Digital Amplifier with Room correction and with FULL $2000 MODIFICATIONS done by ABERDEEN MODS
I am the first owner and have had this amp for less than 2 years;
Comes with a Calibrated mic from TacT but I also have a LINEARX mic which can be sold extra.
Excellent community support for hardware and software.
Please do not read too much into the 150W @ 8Ohms. This digital amp is way too powerful that it states.
Room corrected sound is the ultimate in experience.
PM for details
http://www.tactlab.com/Products/MS2150XDM/index.html
http://www.mauimods.com/TacTAudio.htm
Main Features
Dynamic Room Correction (TM)
• Floating point digital signal processing
• Sophisticated crossover filter package with on the fly filter adjustments
• 12 band parametric equalizer on each channel
• Channel delay time adjustment (time alignment) with approximately 10 micro seconds resolution
• Channel balancing with 0.1 dB resolution
• Channel polarity
• Variable digital gain
• Input signal level monitoring
• LVDS (low voltage differential signaling) for maximum audio signal integrity
DSP Section Inputs/outputs
• Five digital inputs: 3 SPDIF (RCA connector), 1 AES/EBU (XLR connector) and 1 TOSLINC (optical)
• RCA and XLR inputs maximum sampling frequency 192 KHz
• Optical input maximum sampling frequency 96 KHz
• Digital Out: 1 S/PDIF (RCA connector) pass-through for multi amp support
• Microphone input
• RS 232 communication link for PC control
• IR-system Remote Control
• Two 12V trigger inputs
Power Section
• True Digital PCM/PWM power processing
• No low-level D/A conversion
• No analog amplification
• No negative feedback
• 650VA toroidal transformer with dual mono secondary windings
• Second order passive low pass filter using custom-made components
• 90% efficiency - never runs hot - ideal also for discrete custom installations
• Power rating: 150W/Channel into 8 Ohms loadigital amplification and Dynamic Room Correction 2-channel Integrated Amplifer
