Bugle earth
0 Members and 1 Guest are viewing this topic. Read 1950 times.
izerbi
Bugle earth
« on: 24 Nov 2011, 09:28 am »
Hello everybody,
Hope you can help me here.
I have a bugle running fine without any earth connection as my tonearm is a rega rb300 which is earthed through the left ground channel and no problems.
But i'm in the process of rewiring the arm and it will have a dedicated earth cable and here is my doubt, i guessing that i'll plug the earth cable to the integrated amplifier and all good (hopefully!), or am i missing something?
Any advice is much appreciated.
Thank you
poty
Re: Bugle earth
« Reply #1 on: 24 Nov 2011, 06:59 pm »
IMHO it's better to connect to the ground point of Bugle.
hagtech
Re: Bugle earth
« Reply #2 on: 5 Dec 2011, 03:51 am »
Whatever gives you lowest hum and noise is best choice.  I actually added a separate ground wire to my RB300 and disconnected it from cart.
jh
