Roy Johnson on Kevin Voecks
0 Members and 1 Guest are viewing this topic. Read 3705 times.
Roy Johnson
    • http://GreenMountainAudio.com
« on: 22 Apr 2004, 08:37 am »
Thanks TCG!
Glad to be a part.
A customer advised us yesterday of a new interview with the Revel speaker designer- Kevin Voecks, whom I understand to be intelligent, thoughtful and a generally good guy. I respect his accomplishments and how hard he has worked.
In this interview, Kevin states quite clearly, the position of those convinced time coherence in speakers is not necessary. He also states the standard reasoning for not using first order crossovers.
This magazine would probably bust me for printing any quotes from the interview, so I shall paraphrase quite accurately:
Time-coherence isn’t important.
My response: "You are right, if you are listening to test tones/square waves to prove this to yourself- sounds unfamiliar in daily life. Which is exactly how those tests were run to 'justify' a lack of time coherence.
It would seem the best experiment to answer this question would use familiar music or voice as the test signal, spanning the particular crossover point in question, like 3kHz, and played through electrostatic headphones (which are time coherent). Then introduce the time delays of a high-order crossover at 3kHz. Which is easy to do for a cost of about $300 for the electronic crossover, dividing and recombining the signal.
From experience, I know, and many others do, including many, many professional studio engineers, that there is no way to miss the resulting time-domain distortion, unless of course, you haven't really heard that much live, unamplified music- which is indeed possible in the hi-fi and engineering worlds."
Timbre is the biggest thing to get right in a speaker
My response: "Yes, indeed. And you go on to make a lot of good points. However, you leave out that a big part of what forms timbre (texture) is the way the harmonics combine/add/cancel as time passes- we can see that on a 'scope. This is what forms the overall wave envelope! Change their relative timing, change the timbre."
High-order crossovers prevent dynamic compression compared to 1st-order crossovers
My response: "So use better drivers, that have the very least dynamic compression, which can handle the real-world, musical, out-of-band signals presented by a slow-rolloff 1st-order crossover w/o noticable distortion. There aren't many of them, and they aren't cheap, but linearity with power applied is one spec that helps define the very best drivers. The Dynaudio and Peerless raw-driver companies used to publish this info graphically, showing how their drivers reacted over a 0.1Watt to 100's of Watts input range- to differentiate their drivers from the competition."
Loudspeakers that use low-order crossovers inevitably run into these problems.
Wish I'd known this back in 1973, when Hewlett/Packard engineers I worked with demonstrated just the opposite to me, helping me get started in design. Do not see, hear any off-axis problems either, unless you measure only one pure test tone at one very specific point in space- and a pure, single tone is not music.
There are a lot of room problems in the bass with speakers.
And our experiments show that those mostly disappear when the customary 5-8 foot equivalent distance (5 to 8ms of time delay) in the typical woofer or subwoofer crossover is removed. How bout that! A time delay present in most speakers equivalent to the round-trip distance to the wall behind the speaker and back again. Hmmmm. Is it the wall reflection or the speaker?... measures just like a wall reflection/standing wave problem- must be, if we can't hear time-domain distortion...
Here is the link to the full interview: Voecks' interview
Oh well- live to fight another day. But let me leave you with a thought experiment, relative to time coherence:
What does it mean to the band when someone is 10% late? A 3 minute song would end 18 seconds late- several bars late. The beat goes from 105/minute down to 95. Seems easily audible, right?
10%:  on a fairly rapid dance beat of 105 beats/minute (waltz time is 88), one quarter note note is struck every 60/105 seconds, or every 0.57 seconds. Struck and silenced (nearly) and then struck again. All in 0.57 seconds. So the strike and release of the note might itself be only 0.2 seconds. 10% late would be 0.057 seconds late. Or 57 milliseconds. On a quarter note.
Except any musician can easily play 16th notes.
Which means one note struck every 0.57/4 seconds, every 0.14 seconds, or completed in less than 0.1 seconds from start to release. And 10% late would be 0.014 seconds or 14 ms.
Unless it was a 32nd-note run- which would be 7ms (milliseconds).
Imagine the reproduction system shouldn't screw that up by 10% if at all possible. 10% of the 14ms. Or 0.0014 second- 1.4ms. Which is just about, or less than, the time delay one has with side-mounted woofers- which many accuse of sounding slow.
That was for rhythm. For two harmonics combining- we can easily hear the timbre of the voice change with only one microsecond of time delay injected into an otherwise time-coherent design. This change in the sound does not show up on any sinewave test, any pink noise, any MLS test, any FFT, any impulse test, nor on any swept-filter test. But we can hear it- and have demonstrated this to customers, our dealers, and reviewers.  For a decade.
This delay of about a millionth of a second is equivalent to sitting lower in the chair by ~ 2 inches, or instead, just moving the mid back an eighth of an inch- which was our experiment (so one's relationship to the front of the cabinet and other drivers and the room and the chair-back did not change).
The mid was crossoved over at 3kHz. Which has a period of 1/3000 of a second. Of which a millionth of a second is about 1/333rd- about 1 degrees' worth. Which cannot lead to sinewave cancellation of any audible degree, nor can be read at a 100kHz test-instrument sampling rate. But it can be heard reliably, by inexperienced listeners who are simply asked if they hear a difference and if so, what the difference was. All hundreds have agreed.
My view is that when the phase response of the speaker is twisted grossly, then one cannot hear these small changes I just described. That type of speaker is so out of phase it doesn't matter much if one stands or sits. But you also cannot play aggressive or complicated music loudly on that speaker. Ever wonder why "audiophile" recordings are so bland? Don't want to upset those phase anomolies by having multiple tones in that high-voice crossover range... can't play Janis Joplin loudly without upsetting the women in your life- hurting their ears.
Try Janis on excellent headphones- no problem at all. Or on time-coherent speakers.
Thanks for reading this.
Best to all,
Roy Johnson
Green Mountain Audio
Carlman
« Reply #1 on: 22 Apr 2004, 02:01 pm »
Wow, I knew I liked Roy for a reason... he likes Kevin Voecks!  Kevin did wonders with the older Snell's and with the Revel F30.
However, when Roy said "Oh well- live to fight another day. But let me leave you with a thought experiment, relative to time coherence: "
Are you saying 'oh well, at least others are trying' or 'oh well, I'm defeated'.... ?  I thought most of what KV was saying was similar to your philosophy on 1st order xover design and that time coherence was important in listening to music and not test tones.
Anyway, thanks again for posting.  I like what I hear in the Europa's.  They do require some careful attention to positioning to become magical but it's so worth it.
-C
Roy Johnson
« Reply #2 on: 23 Apr 2004, 10:59 am »
Thanks Carl, and I'm glad you like the Europas.
However, let me be clear that I do not agree with Kevin Voecks in many areas-
when he says that time coherence is unnecessary (Snells and Revels are not time coherent),
that measurements in the frequency domain (not in the time domain) can explain nearly everything about what we hear from a speaker and thus how to design a speaker,
that room problems in the bass are caused solely by standing waves,
that all speakers with first-order crossovers are automatically burdened with insurmountable problems and not worth the effort.
The vast majority of press and dealers and consumers believe this is all true, that "time coherence is unimportant". I do not feel defeated, but only like a lone voice, since no other speaker designers seem to be writing about these issues- designers of other first-order speakers- Thiel, Dunlavy, Vandersteen for example, or designers of full-range electrostats. Other designers are definitely NOT trying hard enough.
Best,
Roy
dado5
« Reply #3 on: 23 Apr 2004, 02:04 pm »
Very informative thread.  Thanks much Roy.
While I have not had the pleasure of hearing  your designs, I am, none the less, a first order convert.  Having listened to Vandersteen 2C's about 10 years ago, I have found that I prefer 1st order speakers (except Thiel for some reason).  I currently own Meadowlark Kestrels and I love them.
It is very hard to characterize the what exactly is unique sonically about these speakers.  Seamlessness and coherence come up a lot but these seem inadequate and misleading terms.  For me, It is more of a sense of immersion in the whole of the music that I get from the Vandies, Meadowlarks and Dunlavys rather than a particular aspect that stands out as superior.  I have heard designs that sounded 'quicker', offered a wider soundstage or had deeper bass. In the end they had something missing, or perhaps present, that kept me from hearing all the music. I don't mean "all" the music in the sense of missing some fine detail but rather in terms of the notes connecting to form a whole in realistic way.
Very hard to put into language, but very easy to hear.
Rob
Carlman
« Reply #4 on: 23 Apr 2004, 02:22 pm »
Rob,
I know exactly what you're talking about.  However, I don't care for Vandersteens OR Thiels.  The Vandersteens are too airy for me and the Thiels are too expensive for what they do and sound a bit sterile to me.
I've never heard either of these in MY room, though.  So, I reserve the right to change my mind. ;)
Roy,
Sorry I didn't get that from Voecks' comments.  I understand your point, though.  The Revels do everything right except that real, wholeness to the music that takes it to the near-lifelike presence that the Europa's do.
The Europas are not perfect in every way but I enjoy them for what they get right.... which is that hard to describe thing that Rob describes. ;)
-C
LordCloud
« Reply #5 on: 8 May 2004, 06:34 pm »
I am from a large city and because of it I have been able to listen to a large variety of speaker designs, even some diy ones. I also listen to live unamplified music at least once a week in a small setting (Borders). For me the idea of first order crossovers just seem to make sense, before I knew anything about crossovers I assumed all speakers produced sound as if they had first order crossovers. To my ears all speakers with high order crossovers have one thing missing, realism. My Swifts are not at the zenith of speaker design, but they immerse  me in the music like few others, and those few all use first order crossovers. The first thing I notice about most speakers with high order crossovers is the treble. That might not be a bad thing to most people, but I never notice the treble in live music. I also notice that even though I am getting a lot of detail with most speakers, it sounds disjointed  and constructed poorly, with first order crossovers I dont notice this at all, the music seems to be much more "whole". Soundstaging and imaging also suffer as does image dimensionality, images just don't seem to be "there" like they should be. I am no authority on speaker design and I couldn't design a crossover to save my life, but based on my experience I have to have a time and phase coherent speaker and that means first order crossovers.
Brian Cheney
    • http://www.vmpsaudio.com
First order networks
« Reply #6 on: 8 May 2004, 06:50 pm »
Roy, I want you to know you're not alone.  I have used series first-order networks since 1984 and done pretty well with them.
However, for real coherence (if not the flattest amplitude response) I insist on wiring all drivers electrically in phase, particularly in 3 way designs.  The Thiel and Vandersteen people should suffer untold lashings and punishment for claiming "phase and time coherence" when that statement applies only to the narrowest frequency bands (usually the crossover region) and restricted listening distance and they wire their midranges in opposite polarity to woofer and tweeter.
Hey, if the competition did everything right there'd be no market left for the good guys!
Steve Rothermel
    • http://www.ridgestreetaudiodesigns.com
« Reply #7 on: 9 May 2004, 05:45 pm »
Just one problem with the whole first-order slopes are the "best" for coherence and palpability - there are quite a few loudspeakers that do not have first order slopes but can throw an excellent soundstage with image believably. Examples - Rogers LS3/5a, Spica TC50 (not strictly a symmetrical first order design), North Creek Borealis. Naturally, everyone hears what they want to hear when it comes to imaging specificity and a proper soundstage. In other words, this is a highly personal choice when it comes to prioritizing goals in a loudspeaker's performance.
My experiences have led me to believe that a first order design is extremely dependent on the room and how the off-axis energy of the loudspeaker combines with the room reflections. I find that in order to get the most of a strictly 6dB design I have to sit very close (within 8 feet in a medium size room) to reduce the room's contribution. Then I usually find that I am too close to the loudspeaker as relates to the way the drivers integrate. I end up with an incoherent soundstage where the drivers tend to sing independently and I can hear discontinuety between the drivers. :|
How to resolve this problem? Get a big room and sit slighty farther back so the drivers can integrate seemlessly. Now comes my personal pet peeve - I then hear too much of the room and I become distracted by the room's signature on every recording. (I am especially sensitive to ceiling reflections.)
The point I'd like to make is that (to my ears/in my experience) a strictly first order design brings too many compromises in the real world. When the overall room and loudspeaker set up is taken as a whole, it is much harder to hear the supposed superiority of a slow-slope design over a steeper-slope one.
Warm regards,
Steve Rothermel
Rob Babcock
« Reply #8 on: 9 May 2004, 08:10 pm »
I think your articles here make for damn fine reading, Roy.  I don't always understand it all, but I always read it!
« Reply #9 on: 10 May 2004, 01:49 am »
I'm another satisfied 1st order listener (27 years), but will be leaving the flock to go one better, single driver speakers.
I'm having mass loaded transmission line (MLTL) speakers built for me using Fostex F200A drivers (8 inch diameter, rated 30- 20,000 Hz and 90 dB/w/m raw).  The builder has measured the T/S parameters to customize the cabinet design to the matched drivers and finishing them in my choice of veneer (quartersawn cherry).  The drivers aren't cheap, $375 each from Madisound, but are amoung the highest quality full/extended range drivers available (and so are naturally well matched).
Yes they will have higher distortion and beaming than multiple driver/crossover speakers, but...
1.) No crossover slope/frequency response issues;
2.) No crossover related phasing or efficiency loss issues;
3.) They'll be point source (the ideal for proper imaging);
4.) Which will allow for the ideal nearfield setup;
5.) The beaming characteristics can be used to tune the the treble response;
6.) The bass distortion (minimal for 8 inch drivers) is more than made up for in the quality of midrange provided (what full/extended range drivers do best).
7.) They don't use a whizzer cone, that many consider a mechanical crossover and have, at least on a theoritical level, distortion issues.
8.) The MLTL cabinet design offers extended/quality bass, evens out the impedence hump found in other designs, and clears up midrange response.  (Only via the recent development of design software has MLTLs come out of the trial and error era.)
9.) Between the use of MLTL and single drivers these speakers will present a very simple/easy load for amplifiers.
10.) They will soon be commerically available on-line for around $1,500/pair.
Steve Rothermel
« Reply #10 on: 10 May 2004, 07:14 am »
:o Very good, then! :o
