0 Members and 1 Guest are viewing this topic. Read 966 times.
Marius
« on: 22 Nov 2011, 05:43 pm »
Hi all,
Had à problem with albumart in Max. Anyone know of size demands or limitations? I always make a cover.jpg, but they don't always show. Try to keep them 300x300.
Marius
Ps had à previous post that I could not delete, had to edit, sorry for the inconvenience
« Last Edit: 23 Nov 2011, 06:35 am by Marius »
terrycym
Re: Size of albumart? Cover.jpg
« Reply #1 on: 29 Nov 2011, 08:13 pm »
I use 650x650 and try and keep the file size less than 100k
Never had any issues except...
I use RGB format too as I've had issues with other types of JPGs not showing.
I keep a loose jpg in the same folder as the music and embed it in the music file too with dbPowerAmp
Marius
« Reply #2 on: 29 Nov 2011, 08:44 pm »
HI Terry,
I'll check that RBG format.
Marius
