0 Members and 1 Guest are viewing this topic. Read 12827 times.
For the best reproduction of movie soundtracks you should emulate what is done in the recording studio. They use the same speaker all the way round.
This is hard to do in the home ( three towers is generally not wife acceptable) so the closest most of us can get to is matching the center tweeter with the front two speakers.
Not using a matching center will lead to a different tonal balance, a less than 3 dimensional front sound stage and even possible holes in the soundstage as sounds pan from side to side. If you watch a lot of movies it makes sense to spend the extra to get it right.
