Crossover Glue
0 Members and 1 Guest are viewing this topic. Read 3961 times.
Doublej
Crossover Glue
« on: 20 Nov 2011, 06:20 pm »
I have an inductor that has come loose from its waffle board. What kind of glue should I use to refasten it?
Letitroll98
  • Too loud is just right
Re: Crossover Glue
« Reply #1 on: 20 Nov 2011, 06:26 pm »
I've always used a regular hot melt glue gun for crossover parts.  This was recommend to me by Snell many moons ago.
timind
  • permanent vacation
Re: Crossover Glue
« Reply #2 on: 20 Nov 2011, 07:31 pm »
+1
jtwrace
    • TIPP YouTube Channel
Re: Crossover Glue
« Reply #3 on: 20 Nov 2011, 07:33 pm »
Letitroll98
Re: Crossover Glue
« Reply #4 on: 21 Nov 2011, 03:43 pm »
What?  No third?  I get no support from you people, jeez.   :wink:
Doublej
Re: Crossover Glue
« Reply #5 on: 21 Nov 2011, 03:54 pm »
Thirded.
Thanks folks, that's what I am going to use to re fasten it. With a little luck I be able to get the old glue off and the new glue on without trashing anything or gluing my fingers together.
My 30 year old mismatched Burhoe Crimsons still rock!
face
Re: Crossover Glue
« Reply #6 on: 21 Nov 2011, 11:13 pm »
+4...  :D
Letitroll98
Re: Crossover Glue
« Reply #7 on: 22 Nov 2011, 04:52 am »
+4...  :D
Ahhh, I feel so warm and fuzzy now.
Glad you got a consensus Doublej, hope everything works out.
Æ
Re: Crossover Glue
« Reply #8 on: 22 Nov 2011, 06:14 am »
I prefer RTV silicone.
Hot glues are most often used because of their rapid setup time, speeding production. I personally however do not like the idea of laying a "hot" bead of glue on a capacitor.
Letitroll98
Re: Crossover Glue
« Reply #9 on: 23 Nov 2011, 02:56 am »
Good point Æ, both for and against.  Fast set is critical for many of these repair applications for obvious reasons.  Not to nitpick, but the OP has a loose inductor.  I of course realize you are speaking generally.  However your use of silicone has me thinking of a zillion variables.  Absorption of resonances or lack of rigidity?  Which would have the longer life.  How hot is the glue and at what point could it damage any component.  (Although I will say I've never been advised to hot glue a capacitor)  Seems like such a small thing, a no brainer, but is it?
spinner
Re: Crossover Glue
« Reply #10 on: 25 Nov 2011, 03:56 pm »
+5 : :wink:
rollo
  • Rollo Audio Consulting -
Re: Crossover Glue
« Reply #11 on: 25 Nov 2011, 04:28 pm »
   Zip ties and a dab of Blue Tac under for me. If it were a new crossover being built we use Ebony pen blanks set up like a RR track glued to board with the cap, inductor, etc attached with zip ties and Blue Tac. Extensive however very affective.
charles
SMA
