Soldering station recommendation
0 Members and 1 Guest are viewing this topic. Read 10075 times.
Æ
Re: Soldering station recommendation
« Reply #20 on: 5 Dec 2011, 08:04 pm »
STAHL Tools SSVT Variable Temperature Soldering Station, Holiday Priced at PartsExpress for $12.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=374-100
rajacat
  • Washington State
« Reply #21 on: 5 Dec 2011, 08:11 pm »
I have one of those. You get what you pay for....$12 seems about right. :|
Æ
« Reply #22 on: 5 Dec 2011, 08:15 pm »
I've never seen or used a STAHL, are they that bad?
« Reply #23 on: 5 Dec 2011, 11:21 pm »
Can anyone recommend a good reliable user friendly soldering station?  I plan to do some DIY work (eg, speaker crossover build and also modding electronics).  I'm a novice at this.  I would like a station that can display the temperature.  My budget is around $100 to $200.  Thanks.
Hi,
If you wish a soldering station, Parts Express has a Weller and Stahl have stations.
Weller for $139.00. Part number is: 372-140. (Different soldering tips also available.)
Weller station, part number 372-120 also available for $45.88. Adjustable power 5-40 watts.
Stahl has one, part no. 374-100 for $15.87
Stahl, part no. 374-200 for $59.50
Radio Shack as a basic 30 watt soldering iron that works quite fine for just a few dollars. Your choice.
http://www.parts-express.com/wizards/searchhelp.cfm?search=solering%20station
or catalog for more information.
Cheers.
rajacat
  • Washington State
« Reply #24 on: 1 Feb 2012, 04:39 pm »
Used my new Hakko FX-888 and I must say, for the $$ it's a great little unit right out of the box. Now I need some more tips.  :thumb:
+1
I just bought a FX-888 too. Used it last night and it worked excellently. :thumb: I'm impressed with the construction quality. The iron holder is cast iron. :o Some don't like the colors but I'm OK with them; function is more important. I was going to go with this: http://www.web-tronics.com/70-watt-soldering-station.html but sight unseen, I chose to go with the established brand, made in Japan Malaysia :oops:, with stellar reviews.
hibuckhobby
  • On a search for audio nirvana
« Reply #25 on: 1 Feb 2012, 05:20 pm »
I've had a couple of the "less expensive" brands and finally broke down
and bought a Weller station with dual irons.  BIG difference.
Hibuck...
rklein
  • My finest audio piece ever!!
« Reply #26 on: 3 Feb 2012, 04:21 pm »
I also am ordering the Hakko FX-888  :thumb:
http://www.amazon.com/gp/product/B004M3U0VU/ref=ox_sc_act_title_2?ie=UTF8&m=A19BIX1OPXKM8C
Will the above suffice for my Buffalo III build or should I be looking at any additional tips?
Randy
Delta Wave
« Reply #27 on: 3 Feb 2012, 05:03 pm »
The FX-888 is excellent! I ordered a catalog from them and had it less than a week later, quite a bit of tips to choose from.
