Need help finding parts to build a micro PC for music server
0 Members and 1 Guest are viewing this topic. Read 2905 times.
gregcss
I want to do one of two things 1. By a synology ds111 and internal hdd (cost around $300) OR 2. Build a micro pc and use vortexbox or similar OS for around the same cost as option 1.
I haven't really been able to find parts to build a micro PC and not entirely sure what I need. I assume CPU, MOBO, RAM, power supply, hdd, and case. I just need power and a network port, no need for video, audio, or other ports. I should be able to remote into the micro PC in the same way I remote into my Verizon router, right?
For this reason I am considering buying the ds111 and be done with it but, I think the micro pc would provide more processing power for the money.
TomS
Re: Need help finding parts to build a micro PC for music server
« Reply #1 on: 18 Nov 2011, 09:34 pm »
You might take a look at the Alix thread. Sounds a lot like what you're trying to do.
jeffh
« Reply #2 on: 19 Nov 2011, 04:06 am »
Logic Supply has some very nice cases and MB to build a fanless PC
http://www.logicsupply.com
wushuliu
« Reply #3 on: 19 Nov 2011, 05:26 am »
Maybe
http://www.amazon.com/Foxconn-Dual-core-Barebone-System-R30-D4/dp/B004XLFP9I/ref=sr_1_1?ie=UTF8&qid=1321680190&sr=8-1
A big problem will be hdd cost. The Thailand floods have affected a HUGE portion of hdd manufacturing and now hard drive prices are 2-3x what they were before the floods. This is anticipated to be the case through next year...
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« Reply #4 on: 21 Nov 2011, 11:53 pm »
The guys at geeks dot com have a nice selection of computer for people on a budget. A core i3 pc is awesome for a music server.
A SSD drive would be nice, but they are expensive.
RichP714
    • CARVER site! audio forum
« Reply #5 on: 22 Nov 2011, 12:05 am »
MP3car.com has a good selection of parts; at least the forums are good for ideas when setting up a micro PC.
I ended up with an aopen.com chassis (mac mini size, just a bit wider than a DVD-ROM drive) and separate power supply, then added a touch screen.
I bought the components from ebay; very good price and reliable so far (going on three years)
gregcss
« Reply #6 on: 22 Nov 2011, 05:35 pm »
Thanks for all of the suggestions :thumb:. I'll review them to see what will work best.
mcoaggie
« Reply #7 on: 22 Nov 2011, 05:59 pm »
What do you guys do for power? My pc is fanless with HDMI, digital coax out (P5E-VM HDMI) switching ps makes alot of noise on the line.  Originally built for a home theatre pc but now only plays music.  (My wife didn't like rebooting the TV).    The only thing I've found with enough power is Seasonic X-400 Fanless.
barkerpj
  • PC -> Berkeley USB -> Berkeley DAC
« Reply #8 on: 22 Nov 2011, 07:16 pm »
Check out the CAPS V2.0 build on computeraudiophile.com
a bit more expensive but it sounds great
