Industry Circles
GR Research
Danny Richie
lotta holes to fill
lotta holes to fill
0 Members and 1 Guest are viewing this topic. Read 1976 times.
doug067
lotta holes to fill
18 Nov 2011, 06:36 am »
Wish me luck ls-6/ ls-c build coming up
S Clark
a riot is the language of the unheard- Dr. King
Re: lotta holes to fill
18 Nov 2011, 01:52 pm »
Once you have the cabinets, it's a snap. Danny's diagrams are easy to follow, and there are plenty of us that have built the LS series to help out with any questions.
Scott
kingdeezie
Reply #2 on:
18 Nov 2011, 03:31 pm »
Good luck with the build!
Once you get them built out, the harder job might be getting them acclimatized to that room.
These babies like a lot of space all around to really sound like they should.
Enjoy the experience!
Skiman
Reply #3 on:
18 Nov 2011, 06:16 pm »
Tweeters should be to the outside. Plus, you'll get a much wider soundstage if they are farther apart.
Yes, I realize they're just temporarily positioned.
Industry Circles
GR Research
Danny Richie
lotta holes to fill
