Need replacement tweeters for B&W DM602 SE
0 Members and 1 Guest are viewing this topic. Read 14528 times.
TimeWillTell
« on: 18 Nov 2011, 04:55 am »
I am looking for a little help here so don't beat me up too badly.  My son damaged the dust covers on both tweeters.  :cry:  It looks like I can go in thru the woofer port to remove and replace them.  Can anyone recommend a replacement?  They appear to be 1".
Any suggestions are appreciated.  Thanks in advance.
-TimeWillTell
srb
Re: Need replacement tweeters for B&W DM602 SE
« Reply #1 on: 18 Nov 2011, 05:26 am »
You should probably replace them with the same B&W tweeter.  Substituting another tweeter without modifying the crossover will likely not work or sound right.
I am not familiar with a DM602 SE (nor does B&W list an SE model for replacement parts), so did you mean S2 or S3?  B&W replacement parts are available at http://bwgroup-support.com/partspriceavail.html
DM602 series tweeters are available as complete tweeters or just the diaphragms.
DM602:      ~$72 complete tweeter / ~$58 tweeter diaphragm
DM602 S2:  ~$83 complete tweeter / ~$58 tweeter diaphragm
DM602 S3:  ~$109 complete tweeter / ~$83 tweeter diaphragm
TimeWillTell
« Reply #2 on: 18 Nov 2011, 07:05 am »
S3 that's the ticket.  :lol:
Thank you kind sir we will order the diaphragms.  :icon_surprised:  Do you know if the installation is pretty straight forward?
srb
« Reply #3 on: 18 Nov 2011, 07:53 am »
I've never replaced one.  I think instructions are included with the part, but you may want to contact B&W to make sure.  Here is a Service Manual, but it only shows part diagrams.  http://bwgroup-support.com/downloads/techmanuals/bw/DM602%20S3-TM.pdf
