DAC Parasound 1100HD
0 Members and 1 Guest are viewing this topic. Read 5708 times.
TenhoFrio
« on: 17 Nov 2011, 06:08 pm »
I don't believe you can find a better DAC at this price range and it even tops allot of gear going for 800+€.
I call it the cure for the digitalit.
It uses 2xBurr-Brown PCM63-P chips famous for their musicality, PMD-100 HDCD filter, Black Gate capacitors, etc..
It features 4 push-button switchable digital inputs for all of your sources (2 coaxial, 1 TOSlink, 1 AES/EBU), phase inversion, and LED indicators for frequency and HDCD status.
Asking 214£.
http://www.parasound.com/pdfs/vintage/dac1100om.pdf
Quote:
Manual
Quote:
FEATURES
Four Digital Inputs
Gold-plated audiophile jacks
De-Emphasis Circuit
Balanced Analog Outputs
Gold-clad precision relays
FR4 glass circuit boards
Low Jitter Crystal Receiver
Three Separate Power Transformers
Digital Record Output Jack
HDCD ® Process Decoder
Regulated Power Supplies
Precision Resistors
4 Burr-Brown PCM 63-K DACs
Polarity Inversion Switch
Precision Capacitors
IEC removable AC cord
Silver-plated wiring
Heavy-duty chassis
SPECIFICATIONS
Frequency Response:
2 Hz - 20 kHz, I0.25 dB
Signal to Noise Ratio:
> 108 dB, 113 dB typical
Channel Separation:
> 100 dB @ I kHz
Total Harmonic Distortion:
< 0.0015% @ 1 kHz
Amplitude Linearity:
>100 dB; 102 dB typical
Phase Linearity:
+/- 0° @ 20 kHz
Maximum Jitter:
< 50 picoseconds RMS, (10 Hz 40 kHz) using selected low jitter Crystal
8412 Digital Interface Receiver
D-A Converters:
Two Burr-Brown PCM 63P-J 20 bit, push-pull for each channel and fully balanced digital operation
Oversampling Rate:
8 X (352.8-kHz)
Digital Input:
32 kHz, 4.1 kHz, 48 kHz; Consumer standard SPDIF
Digital Filters:
PMD-100 High Definition Compatable Digital
Absolute Polarity:
0 deg or 180 deg switchable
Digital Inputs:
Coaxial:
75 Ω RCA
TOSlink fiber optic:
EIAJ Standard CP-340/RC-5720, 660 nm typical wavelength
AES/EBU Balanced XLR
Outputs:
Unbalanced Analog Line Out: 3 V nominal, 600 Ω
Digital: 75 Ω RCA coaxial, 0.5 V peak-to-peak
Power Supplies:
3 separate transformers and nine regulators for digital circuits and for each analog channel
Power Requirement:
120 V, 60 Hz, 18W; may be re-wired for 220 - 240 V, 50 Hz
Dimensions:
19" W x 3" H (3 5/8 with feet) x 13 1/8" D
Net Weight:
12.5 lb.
starkiller
Re: DAC Parasound 1100HD
« Reply #1 on: 17 Nov 2011, 07:54 pm »
this would be great but shipping would be a killer :(
