Vinyl display stand
0 Members and 1 Guest are viewing this topic. Read 3223 times.
roscoeiii
Vinyl display stand
« on: 15 Nov 2011, 08:11 pm »
Hi folks,
My Google skills seem to have failed me in my search for this, but I am looking for a stand I can use to prop up and display the cardboard sleeve of the record I am currently playing, and didn't have much luck turning something up.
Any recs either, designed specifically for this or repurposed from elsewhere?
*Scotty*
decal
Re: Vinyl display stand
« Reply #2 on: 15 Nov 2011, 08:44 pm »
Not specificly for LPs but, try this site.
SteveRB
« Reply #3 on: 15 Nov 2011, 08:50 pm »
wall mount option, make it as long as you want:
http://www.nerfect.com/how2rr.html
Wayner
« Reply #4 on: 15 Nov 2011, 09:48 pm »
Ah, the mother of invention. I'd suggest making one. It would be nice to be made from one part (formed polycarbonate, heat formed acrylic), have about a 5-10° tilt-back and be able to accept a triple LP.
4 rubber stick-on feet on the bottom. Sell if for $24.95.
Wayner :lol:
Wayner
« Reply #5 on: 16 Nov 2011, 08:07 pm »
Made a stand today out of some 3/4 x 3/4 x 1/16 aluminum straight angle. I put a 15° tilt to it, but if I made it over, I'd put a 20° tilt to it, tho it is OK.
The bottom and upright is 1 piece that I mitered to get the slope that I wanted, then I simply formed it over. The bottom leg is 6", the vertical rail is 10". The cross piece that serves double duty, buy joining the two sides and acting as the album jacket rest is 7" long.
4 rubber stick-on feet keep the aluminum from scratching anything.
Wayner
roscoeiii
« Reply #6 on: 16 Nov 2011, 08:34 pm »
Beauty Wayner.
Grabbed a business card holder at Office Depot that I thought might work. Nope, on to book holders perhaps. I would be propping up the albums in front of a TV, so needs to be no more than 4" or so high, so as to not block the screen. Many thanks for all the suggestions folks.
Scott F.
« Reply #7 on: 16 Nov 2011, 08:35 pm »
and yet another suggestion....
Amazon Paper Stand
woodsyi
« Reply #8 on: 16 Nov 2011, 08:45 pm »
I use something like this whenever I can,  8) ;)
which is never.
Wayner
« Reply #9 on: 16 Nov 2011, 09:26 pm »
Amazon Paper Stand
That's a nice one. If I needed more from Amazon, I'd get one of these. Oh well, I guess I'm just a hacker.
Wayner :lol:
Wayner
« Reply #10 on: 16 Nov 2011, 09:28 pm »
If I had Woodsyi's vinyl display stand, I still wouldn't be looking at the vinyl art work.....
 :D
twitch54
« Reply #11 on: 19 Nov 2011, 01:00 pm »
you use a cardboard sleeve.....yuk, unless you meant to say 'jacket' , in which case it should be fondled in your lap while listening !!  ...... :green:
twitch54
« Reply #12 on: 19 Nov 2011, 01:03 pm »
which is never.
I looked at her , then your forum moniker........I understand the corolation..... :thumb:
