The digital loop of BAD-1
0 Members and 1 Guest are viewing this topic. Read 2300 times.
john925
« on: 14 Nov 2011, 03:57 pm »
Hi, James
Will the digital loop benefit from the dejitter technology of Bryston?
Will the digital signal input into the BAD-1 be resampled and dejittered before going out from a SPDIF out?
Once I input any digital signal through any input of the BAD-1, the SPDIF out will always send a digital signal out?  Is it possible to turn off the SPDIF out?
many thanks
  • The Demo is Everything!
    • http://www.bryston.com
Re: The digital loop of BAD-1
« Reply #1 on: 15 Nov 2011, 04:15 am »
Hi, James
many thanks
Hi John
The loop just passes whatever it is fed and does not process it in any way.
James
john925
« Reply #2 on: 15 Nov 2011, 06:51 am »
OK, got it...thanks...
terrycym
« Reply #3 on: 15 Nov 2011, 07:57 pm »
What's the BAD-1?
BrysTony
« Reply #4 on: 15 Nov 2011, 08:03 pm »
What's the BAD-1?
I think the OP is calling the BDA-1 a BAD ONE.  I disagree  :lol: :lol:
Tony
terrycym
« Reply #5 on: 15 Nov 2011, 08:25 pm »
Thanks Tony
srb
« Reply #6 on: 15 Nov 2011, 09:52 pm »
I thought he was referring to a new upcoming Bryston Analog to Digital converter, for digitizing LPs and such.
terrycym
« Reply #7 on: 16 Nov 2011, 11:36 am »
Neat! I've been waiting for one of those.
When's it due James.
I presme it will be 24 bit?
terrycym
« Reply #8 on: 17 Nov 2011, 12:58 pm »
Actually, ripping LPs to a memory stick via a BAD-1 (or whatever it's called) might not be a bad idea especially if yo've got a BDP-1?
The ADCs could come straight out of the SP3 (assuming it converts analogue to digital for processing?)
The case for it woudn't need to be too far disimilar to that already used for the Bryston DAC?
JfTM
« Reply #9 on: 17 Nov 2011, 07:07 pm »
Add a Lynx 22 option for the BDP-1?
