Wireless Lan Network adapter For the BDP-1
0 Members and 1 Guest are viewing this topic. Read 3231 times.
Robert D
« on: 14 Nov 2011, 12:39 pm »
How are you connected to the Internet ? Wireless ?
I will need to purchase a Wireless Lan Network adapter For the BDP-1 ... Any suggestions will be good.
Then I will purchase  Apple Ipad 2 ...
Robert
JfTM
Re: Wireless Lan Network adapter For the BDP-1
« Reply #1 on: 14 Nov 2011, 01:20 pm »
I picked up a TRENDnet TEW-654TR from amazon.  Works well for me.
Robert D
« Reply #2 on: 14 Nov 2011, 02:09 pm »
JFTM
Thanks for your feedback
How far is it from your Main Router.
I guess It's just plug and Play ?
Robert
Robert D
« Reply #3 on: 14 Nov 2011, 02:14 pm »
I found this picture... Not the best
I guess that's It !
Robert
BrysTony
« Reply #4 on: 14 Nov 2011, 02:39 pm »
Robert,
Here is another thread about this subject.
http://www.audiocircle.com/index.php?topic=99478.msg1001487#msg1001487
Tony
Robert D
« Reply #5 on: 14 Nov 2011, 03:29 pm »
Thank you Tony
Perfect sir
Robert
JfTM
« Reply #6 on: 14 Nov 2011, 03:54 pm »
JFTM
Robert
Not exactly plug and play,  but set up was easy following the CD directions.
It is in a cabinet (on the other side of a wall) about 30' from my router.
Robert D
« Reply #7 on: 14 Nov 2011, 03:57 pm »
JFTM Are you able to use a computer or I pad ... The hole nine yards works well with the BDP-1
I have a 2 Wire Bell Router  that I'm Connected straight toooo..
My wife is connected via wire less network.... She connects to my Cisco LInksys.
When ever we have friends over they always seem to bring over laptop or Ipad lol......
And they connect to my wireless Network with out a Problem....
Robert
Robert D
« Reply #8 on: 14 Nov 2011, 03:59 pm »
I'm about the same distance away
Are you in Canada ??/
I'm in Montreal
JfTM
« Reply #9 on: 14 Nov 2011, 04:21 pm »
I'm in Montreal
Yes, I'm in Whitby (just East of Toronto).
I love Montreal; Suite 88 on St Denis is my favorite chocolate shop :)
Doublej
« Reply #10 on: 14 Nov 2011, 06:55 pm »
If you have an old wireless router lying around you may be able turn into into a wireless adapter by flashing it with open source firmware, i.e. DD-WRT or Tomato.
I did it to an old Linksys router to connect an HDTV to my home network. Worked great albeit a bit overkill but it cost zero dollars.
JfTM
« Reply #11 on: 14 Nov 2011, 07:22 pm »
Robert
I use MPod on my iPhone, GNOME on my laptop, and can use Bryston's Mini/Max through a browser; all at the same time :)
I'm with Bell as well and other than getting the security code entered properly, I had no issues.
