0 Members and 1 Guest are viewing this topic. Read 5691 times.
I'm thinking the problem is the motherboard.
If it boots up, and everything works, you will know that it's not your BIOS or motherboard causing the problems........again, I'm no expert (-:
Not necessarily, a wonky motherboard will work fine for a while and then have random errors, usually when parts are stressed hard like start-up and any operation that takes some computational horsepower just like a video card driver installation.You could try replacing the battery, a couple of bucks might fix it (but I doubt it).
The hardware I have isn't old technically since I bought the mobo/ram from Newegg in December of last year. The motherboard is a Biostar 945GC-M4 with 4GB of PNY Optima DDR2 667 RAM. The processor is a Pentium 4 3.06, so yeah, it's a bit of a dated system. I originally had Windows 7 (from an upgrade disc) loaded on the machine, but I could never get SP1 to update and the system became buggy so I ended up formatting, loading XP, and I tried to put Windows 7 back on top, but it wouldn't work. Oddly enough, after this most recent format/XP load, I've now been able to install Windows 7 again. However, I'm still stuck at not being able to update it to SP1. This computer is really only supposed to be a data backup/music server for my Transporter. I intend to build a better computer for everyday use and this old slug will go into a closet and connect to my network as the data backup/music server. I guess I could try to contact Biostar and see if they'll replace my mobo under warranty. Problem is, I don't know if it's the mobo, ram, or something else entirely. Something tells me that when I call them about the problem, they'll say it's something else.Kevin T
Your problems may be caused by your memory install of 4gb.......and your motherboard only supports 2gb of memory. Some motherboards will have problems with this and may crash, and some will still boot fine, and run ok .......but only see 2gigs (or maybe 3gigs) out of the 4gb installed. So, it depends on the motherboard. Pull the memory and install a 1gb stick in each slot (you could even just try just one 1gb stick at first).
I might give this a try, but the reviews on Newegg stated that it will accept/recognize 2GB per slot. The computer recognizes 3.49GB which is about right since it's a 32-bit system.Kevin TEdit: I just downloaded the manual from Biostar and it clearly states that each DIMM can handle 2GB for a max of 4GB.
