New GM70-SET amp from Poland
0 Members and 1 Guest are viewing this topic. Read 13825 times.
Re: New GM70-SET amp from Poland
« Reply #20 on: 17 Nov 2011, 10:16 pm »
SAC-Thailand: 6SL7 + 2A3 _ GM70 SET from a custom order
SAC-Thailand: 6N1P + 6BL7 + interstage to two GM70 PP=70W
This does not play, I do not recommend heard these amplifiers
OK, I think I understand what you mean, as 2A3 is much hot and sirupy, etc, 6BL7 could be the same character too.
utopia
« Reply #21 on: 17 Nov 2011, 10:20 pm »
2A3 is not suitable as a driver for gm70,
it just does not play:)
« Reply #22 on: 17 Nov 2011, 10:33 pm »
Ok, thanks for clarify. 2A3 does not work well as 300B??
« Reply #23 on: 17 Nov 2011, 11:01 pm »
Look this SAC 2A3+GM70 amp at underside, I see it use a interstage trafo, to up the signal.
« Last Edit: 18 Nov 2011, 12:25 am by FULLRANGEMAN »
« Reply #24 on: 8 Apr 2015, 03:10 pm »
This tube amp builder is with a web site now:
http://www.amaremusica.pl/
