power tube biasing
0 Members and 1 Guest are viewing this topic. Read 3637 times.
marvda1
  • freelance reviewer: The Sound Advocate
power tube biasing
« on: 13 Nov 2011, 04:54 am »
i had one tube amp manufacturer say bias the tubes with no signal going thru the amp and another say use low volumn music playing.  which is the correct way?
SteveFord
Re: power tube biasing
« Reply #1 on: 13 Nov 2011, 01:39 pm »
Preamp on, no signal is what VTL says.
kingdeezie
« Reply #2 on: 13 Nov 2011, 02:07 pm »
I would think, and I am no expert, that it might be dependent on the type of design and the manufacturer of the amplifier.
The cheekiest thing to say here is to check with whatever company makes your amplifier.
I have Manley's and they say to bias the tubes with no signal, and the preamp off. I follow their bias procedure.
Freo-1
« Reply #3 on: 13 Nov 2011, 02:48 pm »
The old Dynaco MK III owner's manual I had all those years ago did state that the bias should be set with no input (music) signal present.
I think most bias setups are designed to be adjusted with no input signal.
avahifi
    • http://www.avahifi.com
« Reply #4 on: 13 Nov 2011, 03:00 pm »
In general, when the amp is amplifying a signal, this will increase the bias reading.  Thus I would suspect that setting bias while the amp is seeing a signal would give a faulty reading (high).
The problem with the advice to set bias while the amp is generating an output signal is just how much signal should it be playing?  Unless you had the amp attached to a scope, how would you know how much signal is the right amount?
Frank Van Alstine
decal
« Reply #5 on: 13 Nov 2011, 03:07 pm »
The "best" way is the way the manufacturer of your amp recommends. They built it, they should know. Good luck.  :rules:
Ericus Rex
« Reply #6 on: 13 Nov 2011, 05:20 pm »
Biasing without music playing is the standard, so do that unless you amp manufacturer recommends otherwise.
marvda1
« Reply #7 on: 13 Nov 2011, 06:42 pm »
this is what the manufacturer says: " set the volume at lower level (less than one quarter). i guess you could take this as no signal present or with a signal.
Steidl Guitars
« Reply #8 on: 14 Nov 2011, 12:43 am »
Does the amp have a volume control?  If it does, they might mean you should set the volume to low, with no input signal.
marvda1
« Reply #9 on: 14 Nov 2011, 03:36 am »
yes, it is an integrated. i tried doing it with the siginal and the readings kept jumping around, then i tried with no signal and the volume set low and got great readings to set the bias.
« Reply #10 on: 14 Nov 2011, 04:06 am »
Frank Van Alstine
+1. Nicely put Frank.
Cheers.
