Running speaker and subwoofer cables
0 Members and 1 Guest are viewing this topic. Read 1302 times.
milford3
« on: 12 Nov 2011, 04:50 pm »
I just moved into a new condo on the Jersey shore.  The beach is 50 meters from my front door.
I need to set up my HT and run cables under the carpet.  Does anybody know the easiest way to do this?
Bob in St. Louis
Re: Running speaker and subwoofer cables
« Reply #1 on: 12 Nov 2011, 06:57 pm »
To the beach?  :scratch: :lol:
Sorry.
- You can remove the baseboards, and stick the wires in the cavity between the carpet and the wall, then reattach the baseboards.
- You can poke small holes in the jute backing of the carpet and use s "fish" to pull the wires through, but you'll see and feel the wires under the carpet.
- They make "flat" wires that can be taped to the baseboards, then painted to match the trim.
- You can also do wireless, but I can't speak of the SQ.
Bob
youravhandyman
« Reply #2 on: 12 Nov 2011, 08:07 pm »
Easiest way might be to hire someone else to do it.
I can hear Bob cringing and screaming DIY! DIY!!!
Bob in St. Louis
« Reply #3 on: 12 Nov 2011, 08:22 pm »
 :lol: Yip.  :wink:
milford3
« Reply #4 on: 13 Nov 2011, 03:38 am »
Hire someone.  I love it.  Beer me !!
Bob in St. Louis
« Reply #5 on: 13 Nov 2011, 03:19 pm »
I work for beer, but you're too far away.  :lol:
