just got a B&K CS-117, lets take a look inside...
0 Members and 1 Guest are viewing this topic. Read 11096 times.
midfi
  • nisi credideritis, non intelligetis
« on: 12 Nov 2011, 02:47 am »
plugged in to make sure it worked first, (it does...) it sounds pretty good!  but I wanted to open it up to see what I (we) can see and maybe make some small refinements.  This is the view of the unit facing you from left to right...
this is facing the rear left to right...
I need a better camera...
midfi
Re: just got a B&K CS-117, lets take a look inside...
« Reply #1 on: 12 Nov 2011, 05:30 am »
I am no electrical/schematic wiz by no ones stretch of the imagination but I'm a good parts swapper  :lol:. Will the 4 opamps on this board alter the sound as they do on so many other devices? The opamp in the 1st pic is has M9124 LM 833n, the two in the 2nd pic both have PMI op249 gp T9219 on them and the last one to the far right in the 3rd pic has M9130 LM 833n on it.  Any cap or rectifier recommendations?  And I noticed the "balance" knob wont turn more than a few degrees clockwise and counterclockwise from center (lots of resistance), and it has no effect on the balance coming out of the speakers.  That looks like a simple pot swap so I ain't really sweating it.  What y'all think???
Letitroll98
  • Too loud is just right
« Reply #2 on: 12 Nov 2011, 03:03 pm »
I have this preamp, well the CS-115 which is the same one without tone controls, and it's a very serviceable preamp in active mode.  A little hifi sounding, somewhat lacking in nuance.  However look at that direct/bypass button, it switches the unit to passive mode, no active circuits in the signal path, and this transforms the unit to another class.  Lush, beautiful sound, deeply layered soundstage with finely drawn images.  Of course you lose all gain so the source components have to be up to driving the power amp and the dynamics vary accordingly.
Did you get the optional phono board with yours?  Also I believe balanced outputs were also optional on both preamps.  These two pre's were the lower priced option to the Pro 5 and Pro 10 in the line, but all of the early B&K preamps were afterthoughts to the blockbuster ST-140 and later and greater ST-202 power amps that Van Alstine claims were his design.  I'll stay out of that argument and only note that many feel all B&K components were somewhat less than spectacular after those two amps.  They soon switched their focus to home theater and went out of business a couple years ago.
(Not to be a nebbish, but should this thread be in the Solid State circle?)
midfi
« Reply #3 on: 12 Nov 2011, 03:24 pm »
(Not to be a nebbish, but should this thread be in the Solid State circle?)   that's what I was trying to figure in starting it as SS sez power amps and source units and being the anal retentive clown that I am, well...   Maybe a Mod can move it for me because I wouldn't think they would like me to dub a post to two different Circles.  I'll hold my water until then.
