0 Members and 1 Guest are viewing this topic. Read 5916 times.
Gentlemen, Sorry it has taken so long to reply it's been a very busy week....P.S.Mr Behr my deepest apologies for not proof reading my posting better, I will try to do better in the future and I hope that I have not offended your sense of exactness with the English language, something I was never that great with anyway.
I went the biamp route shortly after getting a pair of Double Kronzilla amplifiers. These use the large T1610 tubes. I had been using a pair of Spectron Musician III MkII monoblock amps. Comparing the two showed that the Kronzilla was definitely superior on the mid/tweeter module, but didn't have the iron-fisted control of the Spectrons on the bass module. These two physically separate modules on my VSA VR5-Anniversary speakers have separate inputs designed for biwiring or biamping. I'm running the Krons on the top and the Spectrons on the bottom with excellent results. I've found no problems (to my surprise) with these totally different types of amps blending. I haven't put anything in the signal path in the way of high-pass or low-pass filtering since the internal crossovers in the speakers are still engaged.
Hi Jeffrey,Yes the Spectrons have higher gain than the Krons, enough so that I use an attenuator inline with the input to the Spectrons. I have a two sets of outputs on my ARC REF3, so I can run one set to the Kronzillas without mucking up the SET top end with additional attenuators.
