Is it possible to control JRMC with Apple Remote?
0 Members and 1 Guest are viewing this topic. Read 1681 times.
jb26
« on: 9 Nov 2011, 09:51 pm »
Hi All,
Does anyone know if it's possible to use JRiver Media Center with the Apple Remote, whether via plug-in or other method?
I ask because I find that JRMC sounds the best on my Win7 PC and find the Remote app the most functional of those available. I've tried itunes & foobar2000 for sound, and the my river and rivermote apps, but believe a JRMC/Remote combination would be the best of the best.
This is particularly important to me because my PC isn't very accessible so I rely upon remote access via my ipad or iPhone.
James
toddbagwell
Re: Is it possible to control JRMC with Apple Remote?
« Reply #1 on: 9 Nov 2011, 11:13 pm »
I don't think so.
I am aware of plug player, then the usual remote desktop style programs.
I listened to j.river today, and will likely try it out on the main stereo tomorrow or friday to see if i want to leave itunes...
chip
« Reply #2 on: 9 Nov 2011, 11:25 pm »
Yeah the only one I can think of is the one for the android - http://wiki.jriver.com/index.php/Gizmo
Quick google turned up this for the iphone - http://melloware.com/products/rivermote/
jb26
Re: Is it possible to control JRMC with Apple's "Remote" App?
« Reply #3 on: 9 Nov 2011, 11:42 pm »
chip - thanks, rivermote is one of the third party apps I've tried (I've also tried "my river", which I find a bit better).  It's not bad, but not as good as the apple remote.  Fingers crossed there's a product out there, but I suspect there's not.
chip
« Reply #4 on: 10 Nov 2011, 12:43 am »
What is wrong with the rivermote? Just curious -
jb26
« Reply #5 on: 10 Nov 2011, 12:47 am »
Initially I had a lot of problems just getting it to work and connect to the computer.
In use I just don't find it as smooth as the apple product, particularly when you're trying to browse through albums to choose what you want to listen too.  There's also no native ipad option.
I've read somewhere that you also don't always get access to all albums (something to do with playlists?), but I haven't experienced (or at least noticed!) that problem.
I don't mean to say that it's 'bad', it's just not as good in my opinion.  I actually found 'my river' better than rivermote, and it's cheaper.
