0 Members and 1 Guest are viewing this topic. Read 15189 times.
So a hypothetical then. Given the max dimensions are 17 ft, is it better toa. Reduce the room dimensions to say 10.5x17, orb. Use the max dimensions of 17x17 but use 3 feet of bass traps on either side of the room.?
But the narrower room will still require damping. Right?
i can go as wide as 24 feet!
A rookie question and I hope it does not derail the thread. I hear a lot of talk about using the Golden ratio for room dimensions. WHy is the golden ratio preferred? Can some one point me to material I can read which explains why the golden ratio reduces slap echoes and other audio gremlins? Is this an empirical observation or is this something that come from wave mechanics? Thanks.
