Please check my review of Rega RP1
0 Members and 1 Guest are viewing this topic. Read 3186 times.
granosalis
« on: 7 Nov 2011, 03:46 pm »
Hi,
I wishes to note my review of the Rega RP1 on my blog: http://justhifi.blogspot.com/
Best Regards,
Giuseppe
BaMorin
  • AR turntable rebuilder/modifyer
Re: Please check my review of Rega RP1
« Reply #1 on: 9 Nov 2011, 02:36 pm »
Hi,
Best Regards,
Giuseppe
The RP-1 is a record player, not a turntable. With the amount of run-out in the horizonatl plane, and the factory supplied warp in the platter it would be impossible to set a correct VTA regardless of arm. The amount of wow due to the subplatter being out of round measurable in fractions of an inch vs mills has the speed running all over the place. Tapping the plinth during play can set off drastic amounts of acoustic feedback.  It is the embodiment of a cheap (toy) turntable.
neobop
  • BIRD LIVES
« Reply #2 on: 9 Nov 2011, 03:01 pm »
Hi Granosalis,
Thanks for posting your review. The platter wobble was due to poorly set main bearing?
There's no excuse for that, even with an inexpensive record player.
neo
granosalis
« Reply #3 on: 10 Nov 2011, 01:37 pm »
The issue may comes from the pivot or from the bearing. It could be due to a shock during transport.
I will contact the Rega support.
TONEPUB
« Reply #4 on: 13 Nov 2011, 06:37 pm »
So why write a review of a defective product?
We occasionally get products that are damaged in shipping. (honestly, I'm surprised more stuff doesn't get damaged in shipping)  We send them back and get components in proper order.
Somewhat irresponsible unless you are reviewing who takes the most care in shipping.
neobop
  • BIRD LIVES
« Reply #5 on: 17 Nov 2011, 02:46 pm »
Giuseppe,
Please don't let Tonepub's comment deter you from following up. In the past some reviews took product off the shelf rather than use specially selected samples from a manufacturer that might not be representative of what the consumer actually gets. You really don't know if this was damaged in shipping or defective.
Having specially made product sent to reviewers, used to be prevalent in this business. It probably still is. I'm looking forward to hearing your thoughts about all this, after it's sorted out. It will probably meet your expectations, but please let us know.
neo
