Martin Logan and Bryston Experiences
0 Members and 1 Guest are viewing this topic. Read 2798 times.
mkaiser
« on: 6 Nov 2011, 06:29 pm »
Hi all,
I have a great opportunity to aquire a pair of Spires from Martin Logan at a steal from a dealer close to me and  am also going to purchase a 4bsst2 shortly to mate with it or that is the plan.
I already have BP26, BCD1, Bryston Cables and soon hopefully the new BHA1 when Bryston gets past the metal issues that they are experiencing.
What are your takes on Bryston/Martin Logan?
Mark
won ton on
Re: Martin Logan and Bryston Experiences
« Reply #1 on: 6 Nov 2011, 06:57 pm »
i'm not sure the 4bsst2 will work with the spires due to the low impedance.i was considering vista's or theos but was told i should consider the 7bsst2.i already had the 4bsst2 so after looking at many speakers i wound up getting salk ht-2 tl's.note the 4bsst2 did work very well with my older aerius m-l's
Robin1
« Reply #2 on: 6 Nov 2011, 10:02 pm »
Hi Mark...I've been using a 4bsst with my Martin Logan ascenti's for a few years
absolutely love them.......   magic  :)
niels
« Reply #3 on: 10 Nov 2011, 10:04 pm »
Buy them!!
By the way, think its the first time I heard anyone say Bryston isnt well suited for Martin Logans.
Had my B100 DA and ML Aeon I for five years now and the Aeon I is 4 ohms and 90 db (probably lower now), minimum impedance is 1,1 ohm at 20K.
mkaiser
« Reply #4 on: 11 Nov 2011, 11:16 pm »
Well, i ended up buying them for a good price of $6000 in dark cherry finish. I heard the Summit X and was hoping the Spire would capture most of what it had and it did. Of course, the Summit's do everything a bit fuller and louder. I also got to hear Naime for the first time as their electronics were powering the treble/midrange and it sound very good also.
As for the Bryston 4B not being powerful enought to handle the load of the Spires i believe it is more than enough since the Spires are designed with a powered 200Watt subwoofer and the 4B does 500Watts in 4ohm load. Anyway, food for thought.
Thanks to all that posted their feedback.  :thumb:
Mark
mr_bill
« Reply #5 on: 11 Nov 2011, 11:59 pm »
Mark,
Do you also have a pair of Klipsch Palladiums as pictured in your ID block?
mkaiser
« Reply #6 on: 12 Nov 2011, 01:03 am »
Hi Mr_Bill,
No, i do not own the Klipsch. It was a thought of buying them a few years ago but, the dealer will not get a pair in for me to get re-aquainted with them so no more Klipsch. I heard them about 3 years ago but cannot remember what the damn things sound like now plus they jacked their prices recently.  :?
Mark
