0 Members and 1 Guest are viewing this topic. Read 9481 times.
Everyone here always wants it out of your speakers but... whether you believe it has an effect on health or not is another issue. Studies unfortunately seem to be popping up periodically showing that it does. Anyone ever pulled one of these apart? Is it just a Felix filter? Is it a Neutral to Ground filter capacitor? I am wondering more about how you "remove" dirty power in any potentially different way than say with a power conditioner like Felix. Could the benefit of having such filters throughout the house be a reality? (Obviously you could forgo the CMC)https://www.stetzerelectric.com/filter/It all sounds a little like "magic" but humans that don't understand electricity see it as "magic" - and get shocked because of it - so I don't imagine this is all too much different. Then again who isn't trying to sell the best snake oil?
I did notice that about the filters. They can only eliminate line noise. Line noise does affect whatever is operating, typically by amplifying it to some degree. Also the filters would stop the introduction of line noise from offending devices from entering into other devices. I guess the question is if the devices that create it also create big EMF fields, or if they big EMF field devices only respond to dirty power with dirty EMF fields and do not make it.Hm oh well. Perhaps I have enough high voltage capacitors to try it out, but the only measuring device I have is my own head!
Placing something like a .1uf bypass capacitor across the AC mains is fairly standard application, just make sure the cap is X or Y rated.
I put 4 of them together because I had them laying around. However I am going to use a large one of 25uf (found a $5 panasonic one on Digikey, X1 or 2 I forgot, but it is one its way). 20-30uf is what I read would be ideal by some sorta quaky individuals on some forum that had a long dirty power topic. Plus that is the most I am willing to spend to entertain the idea that there is something I clearly do not fully understand, but am subject too. I imagine this is all the Stetzer's are. I could say a bunch about the effects on a stereo for how much to use, etc, but that is another topic.
Oh I wouldn't call it arbitrarily. There are reasons. The more uf the attenuation, with the more load there happens to be. This is another discussion that I am not really interested in getting into because I have been down it before. The proof of function is in the sound, not the arguing in theory.
