FS: Target TT5T component stand - $79 - P/U only SF Bay Area
0 Members and 1 Guest are viewing this topic. Read 2458 times.
KKM
I have a Target Audio hi-fi equipment stand for sale, these were made in the UK and are very high quality racks, no longer produced by Target and are tough to find on the used market. Stereophile's John Atkinson uses this rack for his components. The metal frame work is all box and tube steel fully welded. It is a 5 shelf unit and measures: 37.5" tall, 17" deep, 21" wide and the shelves measure 19.5" wide by 14" deep. There is 8" between each shelf. The stand can accomodate adjustable spikes on the bottom, but you need to buy your own since I never installed them and are missing. The top shelf also has adjustable spikes to help with leveling and isolation of a turntable, also missing.
The shelf was originally white and I sprayed painted it flat black. A few of the shelf has some slight raised surface from moisture but can't be seen with components on top and can be seen at an angle.
SF Bay area pick up only. UC/Fremont area. 94587
