Solid State Buffer
0 Members and 1 Guest are viewing this topic. Read 3434 times.
Early B.
Solid State Buffer
« on: 4 Nov 2011, 02:05 pm »
I've been reading, with great fascination, the threads about the Dodd buffers and I had been seriously considering purchasing the inline Dodd Buffer to mate with my preamp (I'm in the que for a Warpspeed Octocoupler; other gear is a heavily modded Bada HD-22 CDP, and an Audio GD SA-300SE amp). My only hesitation is the tube. I've had a bunch of tube gear in the past and I'm no longer interested in tube rolling or spending a ton of money on the 6H30P-DR "supertube" which is touted as the best sounding tube for the Dodd. I'm searching for a solid state inline buffer (no volume control). The only one I've come across so far is the Burson Audio AB-160. Any ideas or suggestions? Thanks.
toxteth ogrady
Re: Solid State Buffer
« Reply #1 on: 4 Nov 2011, 02:27 pm »
If you're willing to DIY the Nelson Pass B1 is an obvious choice. Simple build and great sound. If you want to kick it up a notch but slightly more complicated to build look at the dcb1 on diyaudio.
Early B.
« Reply #2 on: 4 Nov 2011, 03:12 pm »
I don't have DIY skills, so I would need to commission someone else to build and "hot rod" the dcb1 for me, if it can be built as a buffer only (no volume control).
roymail
  • Roy in TX
« Reply #3 on: 4 Nov 2011, 03:19 pm »
I recommend you contact Wushuliu with your questions.
srb
« Reply #4 on: 4 Nov 2011, 03:41 pm »
If going the commissioned DIY route, wouldn't it make more sense to build the Warpspeed LDR volume control into the buffer rather than using an external unit with 2 extra sets of interconnects?
wushuliu
« Reply #5 on: 4 Nov 2011, 08:46 pm »
Given the trickiness involved with warp/light speed builds (ldr matching, etc) he may be better off just getting separates, not to mention resale value if the day comes he no longer needs the warpspeed. I would offer to help but he is looking for a finished product and enclosures are my weak spot.
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« Reply #6 on: 7 Nov 2011, 05:04 pm »
I have been using Burson products for some time, and they are reliable. I think this one is a safe bet for your system.
