0 Members and 1 Guest are viewing this topic. Read 9845 times.
Hi Rick, have you worked with raal 70-20xr? And which woofer would be best match with it for a sealed monitor?thx
What kind of -3db point / bass extension do you want for the monitor?
Yes, several designs including the Verita, Prestigio, Cima, and the new Curva which uses a custom version I specified from RAAL. What kind of -3db point / bass extension do you want for the monitor?
12Hz!!! and my wife would LOVE you.
I thought those uses the raal 70-10d? Bass extension is not the greatest importance to me. Im considering acuton,scanspeak ans seas magnesium, but not exactly sure what each posses for midrange. I want something that can throw a large soundstage and that will be powered by a 30-40watts tube amp.
I thought you had purchased the Salk speakers? Looking to move up in performance?
wow Rick u got good memory.Yes i have a pair of Songtower and Ascend sierra. Looking a set up for bedroom and want to step into Raal but im looking for a small monitor rather then a tower. Is the acutton midbass driver a good macth for the raal 70-20? What kind of midrange am i looking? Warm, cold, thin, analytical...??
There are a few different woofers that will work in a smaller sealed box. Do you have a budget range in mind?
Have not thought about budget. Want to get the best but not sure if that will translate best sonically. I kinda prefer a warm side, but i think soundstage and the way a speaker disapear in a room is more important to me.
No holding back here. Tell us what you really think!
Rick, would raal 70-20XR work with acutton Mid c95?
Rick, the grandeur uses revelator scanspeak yet they are more expensives then veritas that uses more expensive iliminator driver.im kinda confused with the pricing. It seems then the verita would be a better buy?
